The following problem occurred...The following problem occurred...
Threaded View
Threaded View
Forum Post 3DCOAT export mesh issue By mtakerkart ( 9 Years Ago )
Forum Post 3d Coat is not the right Tool for create Morph Targets Therefore I... By vidi ( 9 Years Ago )
Forum Post yup 3dcoat does not preserve vertex order so you can't use it for... By urbanlamb ( 9 Years Ago )
Forum Post Thank you for your replies. It's sad because previous 3Dcoat's version... By mtakerkart ( 9 Years Ago )
Forum Post [quote][b]mtakerkart (5/13/2017)[/b][hr]Thank you for your replies.... By wires ( 9 Years Ago )
Forum Post Hi mtakerkart Not sure what version of 3dcoat you are using. I am... By duchess110 ( 9 Years Ago )
Forum Post [quote][b]mtakerkart (5/13/2017)[/b][hr]Thank you for your replies.... By urbanlamb ( 9 Years Ago )
Forum Post [quote]vertex order issue[/quote] It has nothing to do... By vidi ( 9 Years Ago )
Forum Post [quote][b]vidi (5/13/2017)[/b][hr] [quote]vertex order... By urbanlamb ( 9 Years Ago )
Forum Post BTW here ist the workaround to create mophs Important notice !!!!... By vidi ( 9 Years Ago )
Forum Post Ah thanks I would never use it this way anyhow since I dont like half... By urbanlamb ( 9 Years Ago )
Forum Post WhenI try to import in Microvertex mod , 3Dcoat crash with this... By mtakerkart ( 9 Years Ago )
Forum Post I use 3dcoat because the move polygone tool is far better than... By mtakerkart ( 9 Years Ago )
Forum Post [quote][b]mtakerkart (5/13/2017)[/b][hr]I use 3dcoat because the move... By urbanlamb ( 9 Years Ago )
Forum Post I create my morphs in 3dcoat in a different way. File - Import... By duchess110 ( 9 Years Ago )
Forum Post I have not these Character to try it, but the RL CC Bodytemplate do... By vidi ( 9 Years Ago )
Forum Post Thank you Duchess for your answer. But my goal is for facial animation... By mtakerkart ( 9 Years Ago )
Forum Post OOO for facial morph in blender you can make shape keys and they will... By urbanlamb ( 9 Years Ago )
Forum Post Ok I think I now understand. You have a mesh as one mesh and you want... By duchess110 ( 9 Years Ago )
Forum Post [quote]OOO for facial morph in blender you can make shape... By vidi ( 9 Years Ago )
Forum Post @Duchesse Yes I know the pipeline Duchesse and all works with CC... By mtakerkart ( 9 Years Ago )
Forum Post lol :) If its for big mouth movement I think your going to need to... By urbanlamb ( 9 Years Ago )
Forum Post [quote] I think your going to need to get an export license... By mtakerkart ( 9 Years Ago )
Forum Post [quote]But the remedy yes you need to export the full fbx rigged... By vidi ( 9 Years Ago )
Forum Post [quote][b]vidi (5/13/2017)[/b][hr] [quote]But the remedy yes you... By urbanlamb ( 9 Years Ago )
Forum Post I also looked at weretoad on the marketplace after mtakerkart said... By duchess110 ( 9 Years Ago )
Forum Post ...anyhow mkterat assuming the mouth can open you can open it inside... By urbanlamb ( 9 Years Ago )
Forum Post I sent you a PM Vidi :) By mtakerkart ( 9 Years Ago )
Forum Post @Urbanlamb and Duchesse I send you a PM :) By mtakerkart ( 9 Years Ago )
Forum Post I wish you luck mtakerkart LOL. I long ago realized the solution... By urbanlamb ( 9 Years Ago )
Forum Post Thanks Urban :) Cool character! The link was the WERETOAD character... By mtakerkart ( 9 Years Ago )
Forum Post I did get the mouth open using the "ponytail" bone though so the mouth... By urbanlamb ( 9 Years Ago )
Forum Post yesI knew that but it lengthen the process.First I have to do all the... By mtakerkart ( 9 Years Ago )
Forum Post I found this it shows how to make a shape key and move the mesh... By urbanlamb ( 9 Years Ago )
Forum Post Ah thanks I would never use it this way anyhow since I dont like half... By vidi ( 9 Years Ago )
Forum Post [quote][b]vidi (5/14/2017)[/b][hr]Ah thanks I would never use it this... By urbanlamb ( 9 Years Ago )
Forum Post Thank you very much Urbanlamb ! It works with blender now! It's... By mtakerkart ( 9 Years Ago )
Forum Post [quote][b]mtakerkart (5/14/2017)[/b][hr]Thank you very much Urbanlamb... By urbanlamb ( 9 Years Ago )
Forum Post [quote] LOL thanks that was funny anyhow since his 3d coat is... By vidi ( 9 Years Ago )
Forum Post [quote]It's clearly a vertex order problem. [/quote] I have just... By vidi ( 9 Years Ago )
Forum Post [quote] Maybe you has a mistake in the settings and workflow... By mtakerkart ( 9 Years Ago )
Forum Post I dont know why some softwares change this info without us telling... By urbanlamb ( 9 Years Ago )
Forum Post No it is not a Bug it works if you do the right steps ! ;) By vidi ( 9 Years Ago )
Forum Post [quote][b]vidi (5/14/2017)[/b][hr]No it is not a Bug it works if you... By urbanlamb ( 9 Years Ago )
Forum Post As I send to you in a pm , The creator of 3Dcoat said me yesterday: "... By mtakerkart ( 9 Years Ago )
Forum Post I tried the microvertex but doesn't work. I've no "ad morph" in my... By mtakerkart ( 9 Years Ago )
Forum Post What I'm really shure is that WERETOAD IS the problem. Every time I... By mtakerkart ( 9 Years Ago )
Forum Post OK many thanks to Urbanlamb and Vidi for solving my issue!!! They have... By mtakerkart ( 9 Years Ago )
Forum Post [quote][b]mtakerkart (5/15/2017)[/b][hr]OK many thanks to Urbanlamb... By urbanlamb ( 9 Years Ago )
Forum Post [quote] (it works also vidi ) ) [/quote] Yes sure, but in... By vidi ( 9 Years Ago )
Forum Post @Vidi I prefer the ppp mode because you can see quickly bad... By mtakerkart ( 9 Years Ago )
Forum Post [quote]Its good to know i have not lost my mind still I think I... By vidi ( 9 Years Ago )
Forum Post See my above post with the humansnake. I lost the weretoad texture... By mtakerkart ( 9 Years Ago )
Forum Post [quote] lost the weretoad texture when importing to 3dcoat[/quote]... By vidi ( 9 Years Ago )
Forum Post @Vidi The obj I send you is from 3dxchange only. By mtakerkart ( 9 Years Ago )
Forum Post 90 % of my assets exported of 3dxchange works and I get this in... By mtakerkart ( 9 Years Ago )
Forum Post [quote] The obj I send you is from 3dxchange only [/quote] . Like i... By vidi ( 9 Years Ago )
Forum Post This has been bugging me. So I purchased the export version just to... By duchess110 ( 9 Years Ago )
Forum Post Haha I was also just before the cattle to buy, just to test. :D But... By vidi ( 9 Years Ago )
Forum Post [quote][b]vidi (5/15/2017)[/b][hr]Haha I was also just before the... By urbanlamb ( 9 Years Ago )
Forum Post Seems to me you can not accept suggestions or another arguments ?... By vidi ( 9 Years Ago )
Forum Post This was a useful exchange of ideas, I thought. Anyway, there was a... By animagic ( 9 Years Ago )
