Character clothing
Posted By richachd 19 Years Ago
richachd
richachd
Posted 19 Years Ago
Senior Member (383 reputation)Senior Member (383 reputation)Senior Member (383 reputation)Senior Member (383 reputation)Senior Member (383 reputation)Senior Member (383 reputation)Senior Member (383 reputation)Senior Member (383 reputation)Senior Member (383 reputation)
Last Active: 18 Years Ago
Posts: 8, Visits: 76
I m using  Full_Template_Male.max (Given with Iclone)  file for creating clothes a shirt & a trouser using splines, garment maker & cloth modifier and exported it as .vns But when I m importing this character in Iclone & gives motion to character,The character start moving but the clothes remain still at its position. Clothes r not moving according to charcter . Clothes r not attached with the body of the chracter .Pls help how to create character clothing using using splines, garment maker & cloth modifier and animate that charcter properly.
Thanks
Posted 19 Years Ago
I don't know if you have read the developer document "Creating Characters For iClone" but if not I would strongly advise you to do so as it contains some vital information on the issues you have. There are also some video tutorials which are well worth following too. All of which can be found in the Developer Center.
http://developer.reallusion.com/
Basically any clothing you create for the G1 characters needs to be part of the Upper or Lower mesh. If the clothing is separate it will not animate with the character as you are experiencing now. You can't have an Upper or Lower mesh and an additional clothing mesh when exporting to iClone you should combine them into one Upper and one Lower.
Once you have created the clothing you will need to use the Skin Modifier to make sure that the mesh moves and bends correctly with the bones when the character is animated.
I hope this points you in the right direction.
Pete
richachd
richachd
Posted 19 Years Ago
Thanks for the precious information. Actually I have to create a character with only one long gown type cloth, can u suggest smthing to me for this.
Thanks
--Meenakshi
aknzrdude
aknzrdude
Posted 19 Years Ago
Distinguished Member (6.7K reputation)Distinguished Member (6.7K reputation)Distinguished Member (6.7K reputation)Distinguished Member (6.7K reputation)Distinguished Member (6.7K reputation)Distinguished Member (6.7K reputation)Distinguished Member (6.7K reputation)Distinguished Member (6.7K reputation)Distinguished Member (6.7K reputation)
Posts: 2.1K, Visits: 11.0K
well you can always use the long gown clone cloth
richachd
richachd
Posted 19 Years Ago
hi
I m very thankful to u for ur reply.
Now I created the clothing and than use the Skin Modifier to make the mesh moves and bends correctly with the bones when the character is animated.
Now I m facing one more problem i.e when my character moves (or say run) than its legs seems to be coming out from the cloths nd its legs skin is visible.
Pls help me ASAP.
Thanks in advance
--Meenakshi
Lionheart
Lionheart
Posted 19 Years Ago
Veteran Member (749 reputation)Veteran Member (749 reputation)Veteran Member (749 reputation)Veteran Member (749 reputation)Veteran Member (749 reputation)Veteran Member (749 reputation)Veteran Member (749 reputation)Veteran Member (749 reputation)Veteran Member (749 reputation)
Last Active: 13 Years Ago
Posts: 124, Visits: 246
Hi.
I would also be interested in the answer to this as I have a similar problem when using Clone Cloth.  Is there any way to resize the actual clothing layer, as I have discovered that when using - for example - the gown with the Xaria human base, the naked bottom hangs out!
Thanks.
Posted 19 Years Ago
richachd (12/18/2007)
hi
Pls help me ASAP.
Thanks in advance
--Meenakshi
Hi Richachd,
The important thing after applying the Skin Modifier is get the vertex weighting right and this very rarely happens first time and normally requires a lot of tweaking. 3DS Max comes with an excellent tutorial on this if you are new to the process so well worth following first.
After you have the vertex weighting right you may still encounter some problems with skin showing through the clothing and this a problem that also affects CloneCloth users and the long gown. Take a look at the link below for information on this problem. Although it is aimed at CloneCloth users you can adapt the procedure so that it may help you with Max.
http://www.reallusion.com/ContentStore/iClone/pack/CloneCloth/Skirt_help.htm
Posted 19 Years Ago
Lionheart (12/18/2007)
Hi.
Thanks.
Hi Lionheart,
The following link may also help you with the problem of using Xaria and the CloneCloth Gown.
richachd
richachd
Posted 19 Years Ago
Hi
Now my next problem is a texture problem When I expand the legs of my character its cloth texture doesnt remain proper .
You can see it in attached jpg file. pls also give solution of this problem.
Thanks
--Meenakshi
Posted 19 Years Ago
richachd (12/19/2007)
Hi
Thanks
--Meenakshi
Hi Meenakshi,
From the screenshot it looks like you still need to do a little work on adjusting the envelopes and setting the weights as it looks like the right and left leg envelopes are having too much influence on the opposite legs causing the weird stretching.
It is very much a case of trial and error in these situations till you get it just right. Try reducing the size of the leg envelopes to lower the amount of influence they have over the opposite sides of the gown and see if you get improvements in the stretching.
Pete
