stage size
Posted By baddbob 12 Years Ago
baddbob
baddbob
Posted 12 Years Ago
Senior Member (379 reputation)Senior Member (379 reputation)Senior Member (379 reputation)Senior Member (379 reputation)Senior Member (379 reputation)Senior Member (379 reputation)Senior Member (379 reputation)Senior Member (379 reputation)Senior Member (379 reputation)
Last Active: 8 Years Ago
Posts: 8, Visits: 160
what is the cta2 stage size. when i bring ,say a prop (jpeg) it is allways to big, or small.
badd
Posted 12 Years Ago
You can set the Frame Size and Output resolution on the Export page. The area that will then be output will be represented by the Safe Area. You can then add characters and props, resizing as required to fit into the working area either inside the Safe Area or outside.
Please see the Project Settings Help Page HERE for more information.
AverageJoe
AverageJoe
Posted 12 Years Ago
Distinguished Member (11.4K reputation)Distinguished Member (11.4K reputation)Distinguished Member (11.4K reputation)Distinguished Member (11.4K reputation)Distinguished Member (11.4K reputation)Distinguished Member (11.4K reputation)Distinguished Member (11.4K reputation)Distinguished Member (11.4K reputation)Distinguished Member (11.4K reputation)
Posts: 2.4K, Visits: 10.1K
Pixel resolution has a lot to do with how big a prop imports as... Peter, what is the default resolution of the screen and cameras, in terms of dpi? What resolution should props be saved with in order to load normally in the stage, and not be too big or too small. because scaling image props doesn't have the benefit of scaling smoothly like vectors do.
Posted 12 Years Ago
wizaerd (6/26/2014)
Each grid section in CrazyTalk Animator, by default, is 100 x 100 centimetres. So you can use the grid as a unit reference. A character should be on average 200cm tall with a z value of 0.
To maintain quality in your scene, morph based character sizes should meet the following minimums for best results.
Actor Head Size: 750 x 750 square pixels (at least).
Actor Body Size: 1000 x 1000 square pixels (at least).
Actor Hand Size: 200 x 200 square pixels (at least).
