andrew.viney
andrew.viney
Posted 11 Years Ago
Last Active: 11 Years Ago
Visits: 6
Hello. I am trying to silently install this application we have just purchased, so i can deploy it via MDT or SCCM.
I have followed the standard installshield rules and created an iss file using the /r switch, but when i use the /s and /f1 switch, it is not installing.
If i use /f2 and create an installation log file, i get a weird result pasted here: [InstallShield Silent] Version=v7.00 File=Log File [ResponseResult] ResultCode=0
This file should have application information etc in it. The same machine will manually install fine.
Can anyone point me in the right direction ?
Thanks!
Posted 11 Years Ago
Posts: 23.1K,
Visits: 36.6K
Please can you contact Technical Support using the link below. They will be able to supply you with the required information and files for a silent install. http://www.reallusion.com/CustomerSupport/User/QForm.aspx
