Crazytalk 7 Std Silent Installation
Home
Other Reallusion Products
CrazyTalk
CrazyTalk 7
Technical Issues
https://forum.reallusion.com/Topic179114.aspx
Print Topic
Close Window
By andrew.viney
11 Years Ago
Hello.
I am trying to silently install this application we have just purchased, so i can deploy it via MDT or SCCM.
I have followed the standard installshield rules and created an iss file using the /r switch, but when i use the /s and /f1 switch, it is not installing.
If i use /f2 and create an installation log file, i get a weird result pasted here:
[InstallShield Silent]
Version=v7.00
File=Log File
[ResponseResult]
ResultCode=0
This file should have application information etc in it.
The same machine will manually install fine.
Can anyone point me in the right direction ?
Thanks!
By Peter (RL)
11 Years Ago
Please can you contact Technical Support using the link below. They will be able to supply you with the required information and files for a silent install.
http://www.reallusion.com/CustomerSupport/User/QForm.aspx
