Alien Maniac
Alien Maniac
Posted 12 Years Ago
Visits: 2.1K
I use Morphvox Pro and have for many years....works great for me and it is cheap. I also use Audacity but not for voices...... just sayin I enjoy using Morphvox Pro. I also use Scriptvox and it is good too. But real human voice recordings are best.
MSI GE66 Raider, Intel 10th Gen, I7, SC Turbo to 5.3 GHZ, 240HZ, 64GB 3300 Ram, 2x 1TB M2 SSD Drives, NVIDIA GPU RTX 2070/8GB, 55" Sony 4K Monitor External data drives total 7 TB. and an AUDIO Studio Recording system.
theschemer
theschemer
Posted 12 Years Ago
Posts: 1.4K,
Visits: 2.9K
Some good reading here: https://forum.reallusion.com/Topic132009-281-1.aspx?Highlight=voice
And in there you will find: http://espeak.sourceforge.net/index.html
Which may be of some use to you all if you missed it. :P theschemer
gcshep
gcshep
Posted 12 Years Ago
Last Active: 8 Years Ago
Visits: 3.0K
Hi Marwa thank you very much for your input I shall have a look at your suggestion.
maroalone_me
maroalone_me
Posted 12 Years Ago
Last Active: 10 Years Ago
Visits: 128
hello its my first time here in that form .. i used voice changer pro .. last year i brought voice changer 7 . and it was very bad qulity outpout but this year voice changer diammond 8 is very good .. you have a very deffrent ways to chang it to meny voice tone .. this softwear give u 1 year only when i want to used it again next year they ask me renew 20 dollar for new year ... sorry for my bad english but i try to help marwa
planetstardragon
planetstardragon
Posted 12 Years Ago
Posts: 11.5K,
Visits: 46.0K
ya...it does, it's a subtle nuance on the thickness - density and dampening of the reverb on sound. on the singers themselves, trained singers will sing from their abdomen and stomach and have more efficient breathing, but non pros will sing from their chest and head. but again this is specialized ear training - i have spent a lot of years in it. as a producer, part of my gig is to get the best performance out of vocalist, so you can say it's a trained form of troubleshooting and advising a singer. ie - you aren't breathing enough, you are singing from your nose, you are singing from your chest, you are singing from your throat ....the producer is supposed to be able to recognize all these things so that they don't cause the artist to lose their voice when getting power performances. :p Here's a twist - listening to extreme detail almost has nothing to do with how efficient your hearing is, and everything to do with focus and concentration. you could have amazing hearing but not know what to listen for. - so I'd imagine if stevie wonder could see - he'd be distracted by the visualization of a woman's breasts - and not as focused on listening to the detail of the subtle density difference between a heavy woman and a petite woman to imagine what she looks like. also to keep things in perspective, we are talking about voice morphing and stereo-typical profiles of what different singers sound like naturally - if you want a skinny young person, you take off a lot of bass and pitch it higher - if you want a heavier older vocal - you add more bass and low mids and tune it lower.
prabhatM
prabhatM
Posted 12 Years Ago
Posts: 1.8K,
Visits: 8.1K
planetstardragon (1/25/2014) I another 'very important' part - is the eq'ng of the voice .... a petite woman will typically have a higher pitch ...and less bass which matches the physical frame of the body ....
...... for example ..chances are a voice in a room with very thick walls will have a different 'ring' in it's natural reverb, than if the voice were bouncing around in a room made with thin walls. ( hence a heavy woman vs a petite woman !!Not necessarily. Look at famous physically heavy opera singers. Apart from natural gifts, a lot got to do with breath and throat control, so long the heavyness has nothing to do with hormones. And beyond a point, extra thick walls will not make any / much difference.
gcshep
gcshep
Posted 12 Years Ago
Visits: 3.0K
With all this top quality advice I need to sit back and think about putting it into some type of order. I have now purchased both software MorphVOX / ScriptVOX so I think I ‘am going rather busy. Thank you all once again for your input.
Best Regards
George
planetstardragon
planetstardragon
Posted 12 Years Ago
Posts: 11.5K,
Visits: 46.0K
I spent some time playing with the software yesterday - to really make the voice sound different ...you need to focus on 2 points - first your acting - you have to change your spirit - for a lack of a better explanation - of your performance....this makes a big difference, for example...a female voice is typically known to have more 'essss's = some people also speak more from their nose . and articulate clearly ...while other people will speak more from their chest - with less articulation .....while others speak slower and slur more while speaking from their stomachs - and all variations in between .... another 'very important' part - is the eq'ng of the voice .... a petite woman will typically have a higher pitch ...and less bass which matches the physical frame of the body .... there was a rumor that use to go around in the studios that stevie wonder could tell how big a woman's breasts were simply by listening to her voice .....technically if you understand the mechanics of sound ...this is possible ....but this requires an ear training that can distinguish the density of mass and it's effects on a persons voice ..... for example ..chances are a voice in a room with very thick walls will have a different 'ring' in it's natural reverb, than if the voice were bouncing around in a room made with thin walls. ( hence a heavy woman vs a petite woman ) so when you want to imitate a voice - take a moment to focus in on it's nuances and imitate them with acting, compression and eq. which btw, the morph software itself doesn't have all the tools you would need to really dig into the eq...so get it close with the basic graphic eq in the software - then finishing processing in a software like Audacity - for more detail. The software is actually very powerful, Now I have to buy a copy because I was able to change my singing voice into a perfect female voice with the techniques mentioned above. I may be able to give britney spears a run for her money with it ROFL!!
DELETED2
DELETED2
Posted 12 Years Ago
Group: Banned Members
Last Active: 11 Years Ago
Posts: 2.4K,
Visits: 6.1K
I agree with DT on many angles. Morphvox Pro still, if not tuned correctly, gives a compressive ringing that you get with over-compressed audio sometimes. You can filter it out, but the best situation is to use Audacity with Screaming Bee drivers as the processor. Shown on the Screaming Bee site.
What you do NOT get with Audacity is the TIMBRE control. Without this, youre very very limited. Morphvox Pro CAN give you many voices. Most of the better ones are the lower tones from your own or, morphed tones IN your own tone level.
Heres the studio interface. Look at the middle section. Its THERE that the success and failure of the morph exists. The Timbre Shift and Strength. There are many presets on the left, you'll find that your own voice sounds noting like the ones demo'd but they are a rough guide and after selecting one you can then change it by moving the sliders. Headphones are recommended of the feedback is miserable and cancelling out BG noises also cuts vocal quality down too. For the price, and then to record straight into Audacity and THEN tweak and refine is a good starts tool to getting something alternate for your characters. it takes time to refine and you mustn't be afraid to sound like a little elf or a gnome on a bad hair day if you want the best effects. Theatrics is the name of the game. :hehe::cool::w00t:;)
prabhatM
prabhatM
Posted 12 Years Ago
Posts: 1.8K,
Visits: 8.1K
To make your voice sound different, MODULATE differently. For example, if you talk excitedly in your normal self, record that for one character. Then record another just opposite way, deliver your dialogues with long pauses.
Also "copy" different favourite stars with distinct personalities.
Once done, start voice processing with different textures. Use different pitches. Give one file extra bass. Heighten treble in another.
Suddenly, you will have 4 different voices, distinct from each other with Audacity / Voice changing softwares.
Trust me, recording voices is no less exciting than regular animation.
Another quick tip. Use different microphones from 1$ cheap microphones to 400$ mic for different characters to get different voice textures. Infact, for voice recording, there is no good or bad mic. Each one offers different voice texture, provided you can take care of the background noise effectively.
Then record in an open room, in a small booth, inside your cupboard, inside the quilt, from 2" distance with a Pop filter, at a 8" distance without Pop filter......experiment all just to get a different voice texture. Use USB mic for ease of use.
Just remember MODULATION is the key.
