Automatic save
Posted By mavric4610 13 Years Ago
mavric4610
mavric4610
Posted 13 Years Ago
Veteran Member (525 reputation)Veteran Member (525 reputation)Veteran Member (525 reputation)Veteran Member (525 reputation)Veteran Member (525 reputation)Veteran Member (525 reputation)Veteran Member (525 reputation)Veteran Member (525 reputation)Veteran Member (525 reputation)
Last Active: 9 Years Ago
Posts: 13, Visits: 87
An automatic save for projects similar to adobe premier pro would be good.
So that perhaps every 10 minutes or so the project is automatically
Saved.
rcsinger29
rcsinger29
Posted 13 Years Ago
Posts: 782, Visits: 3.2K
Awesome idea, BUT!!!
Make sure there are settings and the auto save uses a temp name or a [ *(1).filename].
I often load a base project, edit, animate, and save as a differnent project. The same base project may be saved into 4 or more different scene projects for a single animation. It would suck to lose my base because of auto save.
This is a much needed feature as I have lost hours of work due to a crash more than once. But it needs to be thought out. Perhaps even an "autosave" folder in the customs directory where all autosave projects are stored.
Cricky
Cricky
Posted 13 Years Ago
Skype ID= learn.iclone
Posts: 2.8K, Visits: 13.8K
Maybe a message in that little message panel at the bottom right of your screen, saying "Backup is needed" should pop-up every ten minutes to remind you that "CTRL-S" should be done now?
This would be a simple solution. It would help those who can't remember to backup regularly.
If you just get in the habit of pressing CTRL+S every few minutes you can create your own automatic backups.
Use the "Grandfather - Father- Son" method.
1st Backup "Grandfather"
2nd Backup "Father"
3rd Backup "Son"
Then start all over again at the top.
If you want an "Automatic" backup, be prepared to stop when you are not ready, so it can do what you can do anyway (CTRL+S). Considering this is not just a video editor and has a lot to compile when "automatically" backing up.
SKYPE ID: rc.650
planetstardragon
planetstardragon
Posted 13 Years Ago
Posts: 11.5K, Visits: 46.0K
my music software has a nice auto save system - it has the regular save function - but creates a back up folder for each project that auto saves in case of crashes.
so if you hit save file - you have File 1
if you crash - you have a series of bak_file_1.fil in your back up folder with the time stamps.
so you get the best of both worlds and when you are done with the project you have all the auto save files in one directory - easy to delete / clean up after you are finished with the project.
Posted 13 Years Ago
This has been requested many times. Thus far no response from RL.
justaviking
justaviking
Posted 13 Years Ago
Posts: 8.2K, Visits: 26.5K
+1
My NLE software (Pinnacle Studio v16) auto-saves continuously.
I'm not sure exactly how it works, but it seems to write to the disk constantly to some temporary file.  If it locks up and you have to kill the process, or the power goes out and your computer shuts off, the next time you launch the software you are given three options, something like this:
  • Resume editing your last-open project
  • Open the last saved copy of your recent project
  • Launch without opening anything
I have had excellent success with the "Resume" feature.
I have had iClone 5.3 lock up on me a couple times already while key-framing some character animations, and I had to use the Task Manager to kill iClone.  That "resume" feature would have been wonderful.
Colonel_Klink
Colonel_Klink
Posted 13 Years Ago
Distinguished Member (18.7K reputation)Distinguished Member (18.7K reputation)Distinguished Member (18.7K reputation)Distinguished Member (18.7K reputation)Distinguished Member (18.7K reputation)Distinguished Member (18.7K reputation)Distinguished Member (18.7K reputation)Distinguished Member (18.7K reputation)Distinguished Member (18.7K reputation)
Last Active: 3 days ago
Posts: 1.1K, Visits: 7.7K
This is a must. Having had Iclone crash several time since I gegan working with it just three weeks ago is very frustrating. At least when Sketchup crashes there is a backup stored so I don't need to start over.
See all my content in one place
https://forum.reallusion.com/uploads/images/a5008f7f-0e1f-4504-bcf8-f262.png
Facebook Page: CWK3D Game and Film Content
Cancer Survivor - Retired Teacher - Geriatric Icloner still learning
Hardware: ZX80; Operating System- ZX80 Basic; CPU - ZX80 @ 3.25 MHz; Memory - 1KB; Hard Drive - N/A; Storage - Cassette; Monitor: Any old CRT TV
Alley
Alley
Posted 13 Years Ago
Distinguished Member (18.0K reputation)Distinguished Member (18.0K reputation)Distinguished Member (18.0K reputation)Distinguished Member (18.0K reputation)Distinguished Member (18.0K reputation)Distinguished Member (18.0K reputation)Distinguished Member (18.0K reputation)Distinguished Member (18.0K reputation)Distinguished Member (18.0K reputation)
Last Active: 3 Months Ago
Posts: 3.7K, Visits: 12.8K
Like Viking, I use Pinnacle Studio and the Auto Save Feature is a life saver (I've used this software since before this was added and remember the frustrating crashes).  However, now if you over tax the program and it crashes, a restart immediately gives you the "Resume" function which works 99.999% of the time.
But....it is a feature people have been asking for as long as I can remember and maybe it's not something that is easy to add to this type of software, as we still don't have it.
Thanks for the Control "S" tip.
Alley
Posted 13 Years Ago
In my experience, saving in iClone 5 is most faster than in previous versions of iClone, so I'm not too concerned about workflow interruptions. And it should obviously be implemented as an option to accommodate those who prefer not to use it.
With IC 5.4 being so awesome :w00t:, our demands are modest...:ermm:
colour
colour
Posted 13 Years Ago
Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)
Posts: 5.2K, Visits: 8.1K
There's a distinction between AutoSave & InstantSave Features in NLE Programs.
AutoSave is User selectable, automatically Loading your Current Project when Launching a Program.
InstantSave isn't User selectable, automatically taking Snapshots of  your Project Edits every few seconds.
Pinnacle Studio has both of the above Features. InstantSave was introduced with S10, which was re-programmed to use Avid Liquid Render Engine, which had the InstantSave Feature..
      REALLUSION FORUM ANNUAL PINHEAD COMMUNITY PROJECTS.
       New Pinhead Website & Project to be announced in September 2015
