iClone 8.4, 8.41 and 8.42 Official Issues Thread
Posted By Peter (RL) 3 Years Ago
6
7
unity_188240 (2/6/2024)
Just updated to 8.4 after having worked on 8.3 and now 8.4 no longer loads. Barely goes to splash page for 5 seconds until it closes. Working on a time sensitive project and made the mistake of updating. Any help would be appreciated. Thanks in advance
Hi...
This issue is often related to graphics drivers. Please check with Nvidia for latest drivers and update if available.
However, if the problem continues, please contact Support using the link below. Thanks.
https://www.reallusion.com/CustomerSupport/UserEx/QSubmit.html?type=product
unity_188240
unity_188240
Posts: 2, Visits: 13
Resolved! Just needed a graphics card studio update. Thank you!
Posts: 5.3K, Visits: 16.8K
UVs corrupt for Mesh_Medium sample terrains.
Those mesh based terrains could be converted to props, but corrupt UV maps nullify this advantage.
Converted props cannot be loaded back after saving.
No other maps (such as bump/normal) could be added to enhance terrain appearance.
Nor could they be sent to CC for geometry tweaking.
Exporting to FBX and importing to Blender immediately revels corrupt UV maps.
(maybe there are 2 sets of UV maps and the corrupt one takes over whenever you to try to manipulate props after conversion)
Please fix it: https://www.reallusion.com/FeedBackTracker/Issue/Corrupt-UVs-for-sample-Mesh-Medium-Terrains
lnickers_724359
lnickers_724359
Junior Member (148 reputation)Junior Member (148 reputation)Junior Member (148 reputation)Junior Member (148 reputation)Junior Member (148 reputation)Junior Member (148 reputation)Junior Member (148 reputation)Junior Member (148 reputation)Junior Member (148 reputation)
Posts: 7, Visits: 143
Hello,
I just purchased the iClone 8, CC4 Upgrade.  When I add an object to the scene it flies away.  This happened from the first launch with no changes and even in new projects.  If i quickly add additional objects, they fly away.  It only happens on the currently selected object-- so adding additional objects allow the previous object to stop moving.  If the camera is selected, it spins and flies away.   I cannot use iClone 8.4 because of this.
Seems to be physics related because the objects spin as the float out of view.
Please help ASAP
lnickers_724359
lnickers_724359
hello,
I purchased the iClone 8 upgrade.  I have iClone 7 with MotionLive, iPhone LiveFace profile,  Kinect Profile and several other Addons.  Do my existing Addons for Facial Mocap in particular work with iClone 8?  I made a significant investment for Mocap and purchased the Pipeline edition of CC3 and also Purchased 3DXchange.  I hope, My plugins for mocap in iClone, will work or be freely upgraded.  Please let me know if MotionLive, and iphone profile will work with version 8?
Nick
lnickers_724359
lnickers_724359
Looking at the properties panel, I can see that the transforms, rotate and position are being updated when the object is selected.  if no object is selected the camera's transform is updated-- causing them/it to fly away.
Please help.
lnickers_724359 (4/4/2024)
hello,
If you look in RL Hub, you should see the availability of updated plugins. They should have been updated free of charge as far as I know.
In the Hub, select iClone 8.x and then look under Add-ons. Available plugins will be there.
flyboyissac
flyboyissac
New Member (15 reputation)New Member (15 reputation)New Member (15 reputation)New Member (15 reputation)New Member (15 reputation)New Member (15 reputation)New Member (15 reputation)New Member (15 reputation)New Member (15 reputation)
Posts: 2, Visits: 9
anyone know why my character textures keep turning white?https://forum.reallusion.com/uploads/images/12ed9471-e027-44ed-bdf2-5f0a.png
flyboyissac (4/24/2024)
Check your Render State in either Scene Manager or on the Modify Panel (see below). It may be set to Smooth instead of Normal.
If it is already set to Normal, try turning off "Progressive Loading" under Performance in Preferences (CTRL+P).
However, if the problem continues, please try updating your graphics drivers as this can also cause display issues.
https://forum.reallusion.com/uploads/images/a8b43993-3449-4feb-a76e-76bd.jpg
I've used Merge Project frequently in the past and find a very useful feature.
However, lately iClone simply crashes rather than doing the merge, even with simple merges of only a single item, such as a prop or camera.
There is an FT entry for that actually: https://www.reallusion.com/FeedBackTracker/Issue/Iclone-merge-projects-crashes-every-single-time.
It says "Assigned" so let's hope for the best.
6
7
