narayankumawat92021
narayankumawat92021
Visits: 10
Hello Sir,
I created a character in Character Creator 4, and during the creation process, the skin texture shaders for different body parts were of various types—some were PBR, while others were Digital Human (based on body part names). This resulted in a specific skin tone for my character. However, when I exported the character in FBX format to use it in Blender and then re-imported the same character back in FBX format, all the shaders for the skin textures changed to PBR. This caused the skin texture to look different from how it initially appeared.
I tried adjusting the shader type in the shader section by using other available shader options, but the skin texture still did not return to its original appearance. Moreover, the original shader types that were present during the character creation process are no longer visible or accessible.
Sir, please help me resolve this issue. How can I restore the original skin texture and shader types?
Thank you.
narayankumawat92021
narayankumawat92021
Visits: 10
Hello Sir,
Thank you.
narayankumawat92021
narayankumawat92021
Visits: 10
agha.khan_940305
agha.khan_940305
Visits: 47
Kindly help. Why I am getting this message.
agha.khan_940305 (12/21/2023)
Hi I have downloaded r eplica Studio plugin, but I do not see it inside iClone 8. Can someone guide me how to add this option to plugin dropdown menu? Regards Agha You can find installation instructions and other tutorials at the bottom of the product page below. These will help you get started. https://www.reallusion.com/iclone/ai-voice-replica/
agha.khan_940305 (12/20/2023) I have created a character with N number of facial points. I like to add animation and speech but lost. The samples on YouTube did not help either. I have iClone 8. Kindly put me in right direction with any samples (on YouTube) to achieve to put speech to my character. Any help will be very much appreciated. To make a character speak you just need to select the Animation tab of the Modify Panel and click "Create Script". There you will have various options to choose from including loading a wav, or mp3 file or recording your voice. Once you get the basics working you can then move on to advanced options like AccuLips. Instructions for doing this can be found in the manual (link below). https://manual.reallusion.com/iClone-8/Content/ENU/8.0/50-Animation/Facial-Animation/Creating_Voice_Script.htmPlease Note: While you learn the basics it might be wise to use the default characters Kevin or Camila.
agha.khan_940305
agha.khan_940305
Visits: 47
agha.khan_940305
agha.khan_940305
Visits: 47
agha.khan_940305
agha.khan_940305
Visits: 47
I started to look Getting Start with iClone 8 - Easy Character Animation Workflow | iClone 8 Tutorial (youtube.com) and started to follow the video. I was able to create my character, where it has 24 facial point for animation. Just follow the YouTube my character is not compatible for anything. Kindly help. My first goal is my character should speak some speech. Please refer to any video.
Posts: 5.3K,
Visits: 16.8K
You may also double-click on the cloth item directly in view-port to select it. It will have a yellow outline after clicking on it.
