Character Creator v4.4 does not show texture on MESH
https://forum.reallusion.com/Topic545257.aspx
Print Topic | Close Window
By agha.khan_940305 - 3 Years Ago
I bought Terminator T-799 from Sketchfab Store. I loaded and updated provided texture.  Shader type to PBR and checked Use sRGB checkbox and set Strength to 100. It does not update. Please note I am loading Arnold.obj not fbx.
By Peter (RL) - 3 Years Ago
Hi...
Do check in Scene Manager under Condition that you have it set to Normal and not Smooth or Wireframe.
Try also changing the render mode between High and Quick Mode from the top toolbar. Does this make a difference?
Then if you are still not displaying textures, please post a screenshot of CC4 showing your character in the viewport and the Material tab of the Modify Panel (displaying the Material List and Texture Settings).
No it does not work.
Kindly check this link for more information.
Reallusion
Please play the video.
Best regards
Agha Khan
By animagic - 3 Years Ago
Your Diffuse Color and Ambient Color (under Material Settings) are black. Set them to white.
Thanks for prompt reply. It worked. :-)
New to Reallusion.
I have created a new character, but the system added underwear to the model.
How to remove it.
Like to add speech to it? I have looked many YouTube videos, but unable to find how to add animation and speech.
Kindly look this link.
Reallusion
 Any help will be appreciated.
Regards
forgot to add linkReallusion
By CtrlZ - 3 Years Ago
Select and delete the pants. You need iClone to animate and add speech. Do you have iClone 8? Have you tried reading the manual?
Best of luck
agha.khan_940305 (12/18/2023)
New to Reallusion.
How to remove it.
Reallusion
Regards
Character Creator 4 is for primarily for creating your characters. You can preview animations already in your library, but If you wish to make them speak or create custom animations for them you will also need iClone 8 as already advised.
To delete any clothes, just select the item you wish to remove in Scene Manager and hit the delete key.
Thanks for reply.
I have everything what is needed. I have iClone v8.4.
Regards
Agha Khan
I am unable to select it, because it is not there, but in view port I can see it. It looks like it is a bug
Looks bug to me.
I am unable to see in Scene but I cann see in viewport.
By 4u2ges - 3 Years Ago
All Cloth and Accessories appear above the character in scene manager.
https://forum.reallusion.com/uploads/images/3a921d2b-bf9d-4fb0-a388-9104.jpg
Thanks. I am new.
You may also double-click on the cloth item directly in view-port to select it. It will have a yellow outline after clicking on it.
I started to look Getting Start with iClone 8 - Easy Character Animation Workflow | iClone 8 Tutorial (youtube.com)
and started to follow the video.
I was able to create my character, where it has 24 facial point for animation. Just follow the YouTube my character is not compatible for anything.
Kindly help. My first goal is my character should speak some speech. Please refer to any video.
I have created a character with N number of facial points. I like to add animation and speech but lost. The samples on YouTube did not help either. I have iClone 8. Kindly put me in right direction with any samples (on YouTube) to achieve to put speech to my character. Any help will be very much appreciated.
Hi
I have downloaded replica Studio plugin, but I do not see it inside iClone 8. Can someone guide me how to add this option to plugin dropdown menu?
Regards
Agha
agha.khan_940305 (12/20/2023)
To make a character speak you just need to select the Animation tab of the Modify Panel and click "Create Script". There you will have various options to choose from including loading a wav, or mp3 file or recording your voice. Once you get the basics working you can then move on to advanced options like AccuLips. Instructions for doing this can be found in the manual (link below).
https://manual.reallusion.com/iClone-8/Content/ENU/8.0/50-Animation/Facial-Animation/Creating_Voice_Script.htm
Please Note: While you learn the basics it might be wise to use the default characters Kevin or Camila.
agha.khan_940305 (12/21/2023)
Hi
Regards
Agha
You can find installation instructions and other tutorials at the bottom of the product page below. These will help you get started.
https://www.reallusion.com/iclone/ai-voice-replica/
Kindly help.
Why I am getting this message.
By narayankumawat92021 - 2 Years Ago
https://forum.reallusion.com/uploads/images/6d269247-6b95-4be8-a575-562e.jpghttps://forum.reallusion.com/uploads/images/0a50cadc-514b-41b5-81f5-3782.jpg
Hello Sir,
I created a character in Character Creator 4, and during the creation process, the skin texture shaders for different body parts were of various types—some were PBR, while others were Digital Human (based on body part names). This resulted in a specific skin tone for my character. However, when I exported the character in FBX format to use it in Blender and then re-imported the same character back in FBX format, all the shaders for the skin textures changed to PBR. This caused the skin texture to look different from how it initially appeared.
I tried adjusting the shader type in the shader section by using other available shader options, but the skin texture still did not return to its original appearance. Moreover, the original shader types that were present during the character creation process are no longer visible or accessible.
Sir, please help me resolve this issue. How can I restore the original skin texture and shader types?
Thank you.https://forum.reallusion.com/uploads/images/b6d8b4cd-8761-4834-83c9-ca8e.jpghttps://forum.reallusion.com/uploads/images/d3f87bc5-9b36-4ad5-a335-1b6e.jpg
Hello Sir,
Thank you.https://forum.reallusion.com/uploads/images/525af258-fb46-48de-841f-4c96.pnghttps://forum.reallusion.com/uploads/images/bb890092-d224-4fc4-8676-aed6.png
