vepop (10/18/2022)
Make a white layer with a circle on it.
Delete the inside of the circle leaving the black line intact.
Use this layer as the front layer.
Place the layer with the animated rain behind this front layer. :)Nice idea. Thanks for trying to help me with this and for experimenting with this.
The way you did it, I can see that the white layer is masking the animation layer so that you only see a portion inside the shape. But it works if I am only using the shape with the animation inside and nothing else on stage.
If I have anything else on the stage it gets covered by the white layer.
The idea is to have a Scene. Then, on top of the that scene, to have a shape with an animation in it. Also to be able to move the shape with the animation in it anywhere on the stage without covering everything else.
In Moho, the mask
layers don't cover anything else and I can move it around on the stage. The layer with the mask is independent from anything else and I don't need a white layer and a hole in the shape to do this effect. I am trying to recreate this in CA4.
But you have the right idea. For just the shape and the animation inside the shape only, I would use your technique if I didn’t need anything else on the stage.
Maybe I am still missing something or CA4 can't do this?
Thanks again!
