Jfrog
Visits: 4.7K
I lost a few hour this morning trying to figure out why The leap motion plugin is not recognized in Iclone 8. I dont have the solution yet but the downloaded Iclone 8 leap motion profile is installing in Iclone 7 instead of Iclone 8. Just so you know ,it doesn<t work in Iclone 7 neither. Please see attached picture. Any help to make it work would be really appreciated. Thank you! 75% of original size (was 675x19) - Click to enlarge 75% of original size (was 675x19) - Click to enlarge
Horror Stories in VR Immersive Sound VR Immersive Sound VR on Oculus TV
Last Active: 2 Weeks Ago
Visits: 31.3K
The path is for a project. The script for the actual Leap Motion plugin (called leapmotion.pyd) should be installed under C:\Program Files\Reallusion\iClone 8\Bin64\OpenPlugin\MotionLIVE\script\module.
Did you install via the Hub? It should list a Leap Motion plugin for iClone 8. I just installed it that way and it ends up in iClone 8.
EDIT: You added some info to your post while I was doing mine. Unfortunately I don't have Leap Motion to test.
Jfrog
Visits: 4.7K
Thanks for the info and quick replay Animagic. Yes, it seems to be in the proper folder but it does not connect. Other plugin such as Liveface works well. 75% of original size (was 675x19) - Click to enlarge
argus1000
argus1000
Visits: 11.6K
I too had the latest drivers for Leap Motion. And it didn’t work. For a long time, I couldn’t make it work. The problem is that Reallusion hasn’t updated its software for quite a while and the latest drivers from Ultraleap don’t work. You have to revert to older drivers to make it work. For me, the V3 drivers were the solution. V3: https://developer.leapmotion.com/releases/leap-motion-orion-321-39frn-3b659 V4: https://developer.leapmotion.com/releases/leap-motion-orion-410-99fe5-crpgl
My latest movie THE GOLDEN MAN, and a few others: https://www.youtube.com/channel/UCIl1EqVCKitZzLqaNnLK0BA
Jfrog
Visits: 4.7K
@argus1000 Thanks for the infos. I can not believe I spent all day trying to make this work. Earlier I was able to see the handtracking in the leap motion control panel but Iclone would not connect to the plugin. So I made several attempt to fix this, like restoring the default setting in the Leap motion control panel. I also updated the leap motion firmware. I also installed v3 , so now iclone connect to the plugin but I can't see anything moving while using the preview or record + spacebar. I can see my hands in the leap motion control panel but I dont see the graphic of the dummy hand following my real hands. All light are green in the troubleshoot control panel so I am out of ideas here. 75% of original size (was 675x19) - Click to enlarge
xiaobingb
xiaobingb
Visits: 203
Where should I download Iclone 8 leap motion profile?Thanks!
Visits: 31.3K
xiaobingb (9/22/2022) Where should I download Iclone 8 leap motion profile?Thanks!It should be listed in the Hub. 75% of original size (was 675x19) - Click to enlarge
xiaobingb
xiaobingb
Visits: 203
Thank you very much
xiaobingb
xiaobingb
Visits: 203
I get the message:
Unfortunately, Leap Motion Profile has been discontinued. So it was no longer to sell and removed from the Software Store.
