NinjaMouse
NinjaMouse
Visits: 253
I'm having texture issues when bringing my modeled clothes into CC3. In Blender, I baked my PBR textures to PNG format, and exported the clothing model in FBX format. In CC3 (latest version) I create an accessory from the FBX file and convert it to clothes like I always do. But when I add the textures to the PBR (or any other) shader, there are problems. The normal maps have no effect--I crank the slider up, but no effect is visible on the clothes. I tried a TIFF version of the same normal texture, but it did nothing as well. Also, the base color texture doesn't respond to the adjust color panel (e.g. sliding "hue" back and forth does nothing). The imported PNG version looks fine in the original colors, but can't be changed. When I import a TIFF version of the same texture, the color changes as expected.
Why might my textures not produce normal effects or allow for color changes? Are there common reasons for this? It works fine in Blender. The model is properly UV unwraped.
Any help would be greatly appreciated.
Posts: 9.2K,
Visits: 22.1K
Are you saying the maps show up in CC3 but don't work? IOW, you select your clothing item and in the Roughness slot you see a b/w map of your roughness? But no matter how you adjust this it doesn't do anything? PNGs won't work for opacity (you need to use JPG) and TIFs are always suspect, but otherwise maps in the roughness/metallic/bump slot should work just fine, assuming you told CC that the map you put in the bump channel is indeed a bump map and not a normal map (if you told it otherwise then you need to remove it and add it again). And remember that FBX does not contain any other maps other than diffuse and opacity - all other maps need to be added manually into CC into the various slots.
3DPiXL
3DPiXL
Last Active: 11 Months Ago
Visits: 2.8K
Don't save the texture maps in 16bit or they won't have any effect in iC/CC
Reallusion Tutorials and Tips: https://www.youtube.com/@3DPixl
