(2022.Jan.30 updated) iClone 8 and Character Creator 4: Work-in-Progress Preview - Part One
Posted By Miranda (RL) 5 Years Ago
Rated 4 stars based on 5 votes.
6
7
8
20
(2022.Jan.30 updated) iClone 8 and Character Creator 4:...
Ascensi
Ascensi
Posts: 262, Visits: 1.9K
@helielfilmz I've asked for a better physics system on the feedback tracker that can be used on Characters as well to have discreet physical interactions like punch, pinch, grip and pull etc.  If it had a grid based particle collider spread evenly over body parts/materials, Screen space particle colliders might be an ideal solution for fast real time performance that could work between two Soft Body Characters at the same time using mocap!
It's listed under 3DXChange but I since noted it should be for iClone as I realized what is possible making my own Softbody Physics Character working in iClone,
If you like the idea, please vote for it here:  https://www.reallusion.com/FeedBackTracker/Issue/Request-to-allow-Softbody-Physics-on-character-s-skin-influenced-areas-are-to-determined-by-weight-map-painting
I don't know if they've finalized what will be added for iClone 8,  the votes are adding up fast!. iClone does have softbody physics for objects and it requires decent mesh resolution for proper deformations. Hair UV strips for the physics texture should be pure black at the root and gradually end with grey, so if you create hair its good to line up the UV hair strands straight & vertical with the roots at the top and tip pointing down for consistency and easy control.
Store Page Link
https://forum.reallusion.com/uploads/images/906a14b0-c792-4382-99ee-7dfe.jpg
GIM
GIM
Posts: 120, Visits: 7.4K
Yep, feel exactly the same way and this has ALWAYS been an escalating issue with RL 'upgrades'. I've been with them since iClone2 and have most of their stuff. However, the content store contains nothing but junk when trying to use it in Unreal Engine. I've had to return everything I've purchased from the content store to use in UE as none of it works, too many material/shader issues.
So what if I buy 800 bucks worth of useless store content, get the free iC/CC upgrade then refund the useless content???
TheOldGuard
TheOldGuard
Senior Member (439 reputation)Senior Member (439 reputation)Senior Member (439 reputation)Senior Member (439 reputation)Senior Member (439 reputation)Senior Member (439 reputation)Senior Member (439 reputation)Senior Member (439 reputation)Senior Member (439 reputation)
Posts: 15, Visits: 172
I just want to confirm that based on section 7 we do not have to actually Apply like you do with Elite 2022 program ?
And that we will just be emailed to confirm we were successful in Jan 2022 ?
https://forum.reallusion.com/uploads/images/09995f9e-3aa8-4328-8297-cefc.png
mtakerkart
mtakerkart
Distinguished Member (16.8K reputation)Distinguished Member (16.8K reputation)Distinguished Member (16.8K reputation)Distinguished Member (16.8K reputation)Distinguished Member (16.8K reputation)Distinguished Member (16.8K reputation)Distinguished Member (16.8K reputation)Distinguished Member (16.8K reputation)Distinguished Member (16.8K reputation)
Posts: 3.2K, Visits: 29.2K
Really cool Reallusion !! The implementation of volumetric lighting is such a simplicity shows how far ahead you are compared to other apps.
I would add the same thing for the creation of the animation, indeed put back the "director" function that existed in version 5 shows how visionary you can be.
If by any chance you offer an open beta for people who pre-order then I would change my
financial priorities. Otherwise I would wait until next spring.
Congratulations
ReiniWien (11/4/2021)
This is true. I bought a lot of things and i know i will spend money in the next time but not under pressure because to be honest: at now there is not enough content available. i own the assets already.
so da-points should be a good compromise…
DA points are like money in the bank that doesn't necessarily benefit RL if you spend it on third-party content for which RL only gets a percentage.
Hmm, I just realized after I wrote this that the same holds for third-party stuff from the Content Store.
matenn30
matenn30
Posts: 471, Visits: 3.3K
TheOldGuard is a great challenger. I plan to buy multiple Chibi Chibi Weekly Specials and buy a moderate one, such as iclone7, for $ 799 in the second half of December. I'm sorry, it seems to be mounted, but this is my way of buying. This iclone product is a way to bear fruit in the opening of future lesson classes. By the way, I got permission from the realization company. The rest is permission from the parents' family.
TheOldGuardさんすごい、チャレンジャーです。自分はちびちびウィークリースペシャルを複数台購入しまくりし12月の後半に適度なもの例えばiclone7等を799$分購入する計画です。すいませんマウント気味ですが、これが自分の買い方です。このicloneの商品は、将来のレッスン教室開講開業で実を結ぶ手段です。ちなみに自分はリアリュージョン会社元に許可をもらいました。あとは父母家族の許可です。
By the way, the weekly special is real illusion once a week in Japan from 9am on Thursday to once a week in the US on Wednesday, but I don't know what time it is, but you can buy multiple real illusion products from 1 to 10 $ or more at that time. is. It saves a lot, but I don't know which product will come out.
ちなみにウィークリースペシャルは、リアリュージョン日本で週一回木曜九時~アメリカは週一回水曜何時か分かりませんが、その時のリアリュージョン製品1から10$以上のもの1品を複数商品買うことです。結構節約になりますが、どの商品が出るのか分かりません。
Weekly specials are also available in the corner of the content store by scrolling and clicking. And the content and export licenses are cheap, as I say many times, I buy more than one to open the classroom.
また、ウィークリースペシャルは、コンテンツストアの隅にありスクロールしクリックすると出ます。そしてコンテンツやエクスポートライセンスも安いです、何度も言いますが、自分は教室開講の為に複数購入します。
This is an important and careful review of the basics. Realization product software and contents are 1 unit purchased 1 ID 1 content 1 unit. Offline Online Especially if you purchase multiple items and use them at the same time, add 1 to each.
これは基礎おさらいで重要で注意です。リアリュージョン製品ソフトやコンテンツは 、1台購入1ID1コンテンツ1台です。オフラインオンライン特に複数購入し同時に使う場合は1それぞれ追加ですが。
The forum is an amateur.
フォーラムは素人です。
ReiniWien
ReiniWien
Senior Member (484 reputation)Senior Member (484 reputation)Senior Member (484 reputation)Senior Member (484 reputation)Senior Member (484 reputation)Senior Member (484 reputation)Senior Member (484 reputation)Senior Member (484 reputation)Senior Member (484 reputation)
Posts: 27, Visits: 578
animagic (11/6/2021)
I think, for our productions we will buy the best content available because we want the best results. So we mainly buy content from contentstore. it would be ok to exclusive reserve this DA points for reallusion software and content. In this way they get 100% of my money :-)
gm.mikelryan
gm.mikelryan
New Member (19 reputation)New Member (19 reputation)New Member (19 reputation)New Member (19 reputation)New Member (19 reputation)New Member (19 reputation)New Member (19 reputation)New Member (19 reputation)New Member (19 reputation)
Posts: 2, Visits: 55
you can use the free vesion of houdini with fbx to add good rag doll physics to your animations
GIM (11/5/2021)
You can only refund content up to 14 days after purchase.
However, if you were to obtain iClone 8 and CC4 fraudulently in any way then your serial numbers would be cancelled and the items removed from your account.
joao.henriques
joao.henriques
Senior Member (474 reputation)Senior Member (474 reputation)Senior Member (474 reputation)Senior Member (474 reputation)Senior Member (474 reputation)Senior Member (474 reputation)Senior Member (474 reputation)Senior Member (474 reputation)Senior Member (474 reputation)
Posts: 31, Visits: 1.7K
I will spend around 1k in motions and stuff but only if at least I have the possibility to export body morphs to unreal... will this be a feature of iclone8 ?
6
7
8
20
