CC to Blender and back to CC
Posted By togu3d 4 Years Ago
togu3d
togu3d
Senior Member (280 reputation)Senior Member (280 reputation)Senior Member (280 reputation)Senior Member (280 reputation)Senior Member (280 reputation)Senior Member (280 reputation)Senior Member (280 reputation)Senior Member (280 reputation)Senior Member (280 reputation)
Posts: 17, Visits: 51
Hello again, Im having quite a situation with the Morph slider and could use some advice!
I understood the workflow and it worked perfectly, the problem is with a different mesh I started today. Its been sometime I did the CC>Blender>CC workflow, so I didnt pay attention and imported the .obj direct in Blender, not through the CC addon. Then I worked for several hours in the model face, just to realize now Im unable to import back into Character Creator.. is there some way I can get it working without wasting so many work hours? I did try importing another mesh, this time using the CC tool, cut out the head and replace by my edited mesh, but it didnt work. When Im creating the Morph slider back inside CC3 it wont accept the objkey, most likely because I replaced part of the original mesh.
Any advices?
Thanks!
Posts: 5.3K, Visits: 16.7K
Oh well, I know it's kind of easy to use CC add-on for making morphs, but I never use it for that.
For morphs, I always use a direct import/export to/from Blender (and know by heart import/export settings) to avoid this kind of complications.
You cannot use the model you morphed for importing as a slider to CC in any way, unless you checked Keep Vertex Order and Polygroups on import to Blender (which I am sure you did not).
The only way to handle it now, is to transfer the shape to other model (correctly imported to Blender):  https://forum.reallusion.com/FindPost482754.aspx And I hope you exported the original model for morphing as OBJ in bind pose - body.
Now you have to mask a tongue (with mask modifier) for both, source and target model and transfer the shape. Look at the Video tut (second post at the thread above) and try it out.
In your case you'd need to transfer the shape for whole body, which is even easier.
If you do not have vertex groups for body and tongue for your originally imported model, you may even delete tongue all together from it.
Then only mask tongue using CC_Base_Body group on a target and use the same CC_Base_Body group for mesh transfer.
Let me know if you have questions, or stuck at some step.
Here is a routine for a full body transfer: https://forum.reallusion.com/FindPost493559.aspx
togu3d
togu3d
WOOOOOOOOOOW!!
Thank you SO MUCH for the advice! This tool is amazing, and the video tutorial you added is awesome and will certainly help a lot new users such as me, importing their stuff back into CC!
togu3d
togu3d
Im having an issue doing the mesh data transfer. I think when I exported the .obj I left the default "Full Body" option on CC export prompt, so my mesh has all extra details like tear line, teeth and maxillary with a lot UV overlaping;
I guess I will be forced to remove these mesh for the mesh transfer to happen, can I add it later back in CC without big issues?
If you exported a full body, then you'd have 2 options:
1. Import neutral base (body only) for target. And then delete eyes, teeth, eye occlusion, eye tear line and tongue meshes from the original character.
Leaving only body, eyelashes and lacrimal. Then transfer body shape as shown in the video.
In CC you'd also have to tweak eyes and teeth bones for correct placement as shown.
Occlusion and tear line are optional meshes and easily added from modify panel with Enhance Eyes button.
If you had custom skin for the original character in CC, you may save it in Skin > Overall folder and reapply it, once you import morph slider to a neutral base.
Same goes to eyes and teeth, you may save them separately from original character in CC and reapply to morphed neutral base.
2. I just found this out and successfully tried it.
You may actually import a full body neutral base and successfully transfer "whole thing", including eyes, teeth, etc.
But here is a catch. You would have to spread UV tiles for both source and target avatars uniformly so that there is NO single UV overlap.
Here is my UV map after arrangement (must the the same for both avatars):
76% of original size (was 666x19) - Click to enlargehttps://forum.reallusion.com/uploads/images/40dfa44e-a9db-4d92-b674-79b6.jpg
To be on a safe side, I was also making sure to have right and left tiles for eyes, cornea, occlusions and tear lines do match between avatars.
Tiles location quadrants do not matter as long as there is a match between avatars.
Moving tiles is easy. Once respective tile/mesh is selected, use the following command:
G Y 1 moves 1 quadrant up
G Y -1 moves 1 quadrant down
G X 1 moves 1 quadrant to the right
G X -1 moves 1 quadrant to the left
That also means there is no need to mask a Tongue with modifier anymore for body only import. Moving a tongue tile 1 quadrant down for both avatars is sufficient enough for successful transfer.
togu3d
togu3d
Thanks a lot for all support and help, I would certainly not be able to get it working without the advices and video you posted!
Gladly it was just the overlaping UVs that were causing me problems, after I removed the extra geometry from my mesh it managed to transfer the data perfetly! The tear line, mouth and everything else behaved just fine when I imported the mesh, I only had a couple issues with the sale, but after fixing it in Blender everything worked alright!
Thank you so much! :D
No problem. Glad it helped! ;)
