Dan Miller
Dan Miller
Last Active: 7 Months Ago
Visits: 1.8K
New to this Reallusion software (but been on computer graphics for 36 years...) and I'm having a problem getting LIVE Face to connect with iClone.
Are you placing colon and 999 at the end of the IP number? For example, 192.168.1.4:999
AlbinosGambit
AlbinosGambit
Visits: 478
@danmiller (4/6/2020)
Thanks for the video demo:-) Looks pretty good and decent results, what do you think? By the way here is my first animation for walking down the stairs challenge:
Masterclass.com I am familiar with, I watched the best player in chess history GM Garry Kasparov. Yes, I am a chess player:-) They have many decent classes. What're the classes you will be attending? You say: I came from an aviation background and the training path is well documented. If you want to hold a specific certificate or rating, then everything you need to learn is clear. I think this field needs a bit more of that. Something where new people can see a clear path and understand what they need to learn to ultimately become an animated filmmaker. I totally agree with you, the learning path should be more clear. I find learning very difficult, so I decided to take private lessons in iClone from a very good instructor with 10+ years of experience, also the forum is great for giving us insights as well! DM you what does that mean?
WIN 10, COOLERMASTER MASTERCASE 500H, MSI GAMING PRO CARBON X470 RGB, AMD Ryzen 7 2700X CPU, MSI GeForce GTX 1650 GAMING X - 4GB GDDR5 RAM GPU, Corsair Vengeance RGB PRO DDR4 3200MHz 16GB RAM, SSD M.2 Corsair Force Series MP510 480 GB, SEAGATE BARRACUDA 3.5 HDD 4 TB.
Best regards Albin (AlbinosGambit)
Last Active: 5 Months Ago
AlbinosGambit (4/11/2020) DM you what does that mean?
the ":999" at the end indicates the port number. It's like the IP address is your house and then the port numbers designate various entrances and exits. There are certain set port numbers for specific applications and usually you don't have to worry about them. Now a firewall may block them, so you may need to make sure that Port 999 isn't blocked if there are issues. I'm not an expert at this at all, I just pick up little bits of information...:unsure:
AlbinosGambit
AlbinosGambit
Visits: 478
?! animagic (4/11/2020)
Dan Miller
Dan Miller
Visits: 1.8K
No problem, you're welcome. I'm glad Mike Kelley brought it up. I think the results are pretty good for just pointing the iPhone at a person in a video. But it does bother me that the tongue doesn't move so maybe it would be better to record a viseme track at the same time, which would also help with audio sync.
Yes, I think you have made good progress with the stairs and I like it. However, I still see the same issue with this approach. It takes a long time and there is still foot sliding and contact issues. It probably sounds like I'm critizing you but I'm really not. I am skeptical of this forward kinematics approach to the problem. Every time you have a new set of stairs then you have to basically make a very specific animation for those specific stairs. It seems like a pain point that needs a different solution. But don't let me take away from your progress, overall I think you did a great job.
I will be looking at anything filmmaking related on masterclass.com.
Awesome, glad to hear you found someone to give you private lessons. Yes, much of my energy moving forward will be about making the entire process easier. But hey, I have a lot to learn :) Everyone approaches problems differently. I have to see the larger picture first and then drill down into the more specific areas. You are thinking about animation and I'm thinking about distribution. So, as you can see, I start at the end of the pipeline and work backwards.
DM just means direct messaging.
AlbinosGambit
AlbinosGambit
Visits: 478
@ danmiller
Hi Dan, Yes, I think the Faceware with just using an iPhone gets decent results but could be better and for the price you pay to get such results then I think it should be even better because still, you have to do some tweaking and work to get it right. Regards to my stairs animation, I think it' important to tell the truth and I am not offended in any way. I believe this is the best approach to let me know what I did wrong so that I know exactly what I need to work on:):D You are right regards to different stairs different approach, doing things manually takes a lot of time, I was also hoping for an easier solution like Anima has. Anima takes mostly care of the walking process itself it seems to me, although I do not know the software. The animation should be logical and a clear path for learning, with iClone and CC3, I feel I take 1 step forward 2 steps back all the time. The manual is not meant for us noobs, it seems like its made by people who already have the knowledge, so the manual is almost always no help. I have to ask the community all the time for solutions, and also many times the community is helpful but still, we get answers that are at a much higher level. It may seem logical to them but not clear at all to us noobs. But I do appreciate the helpful community, they have value in gold:):D Yes, I felt like private lessons are the way to go in the start to get a grip and feel of the software because right now I feel it's hard to learn and see a clear path what to do. I just bought: The Animator's Survival Kit, Expanded Edition
Recommended by Benjamin this is a must-have to learn from the book and test out the examples from the book inside iClone. Also, watching 2D animation could be really helpful to master animation, it's easier to understand.
Let me know what master class you attend and how it is:-)
HimAnI_Kev
HimAnI_Kev
Visits: 88
Sorry for the delay... Was lucky to have some freelance work this week. Tried this again. As I said, I have an iPhone 11 Pro Max, and I've tried many last digit numbers in case one was in use by somwthing else, but I still get this result. It never activates. This process is pretty simple, but what could I be missing? Thanks for the help - KK
HimAnI_Kev
HimAnI_Kev
Visits: 88
Yes. I just posted some screen grabs...
Posts: 9.2K,
Visits: 22.1K
LOL -- sorry, but you're still not *quite* getting it. Here's what to enter: 192.168.1.9:999 (You just are confusing the last "9" at the end with the 999 device number -- both need to be there, separated by the colon).
HimAnI_Kev
HimAnI_Kev
Visits: 88
Thanks! That worked... Technically. It connected and I recorded some face capture: Really jerky and popping. Then on my next recording an eye froze shut, then the whole head. I started a new project, loaded up the stock female character and couldn't connect again, even setting the wi-fi address correctly. So that solved the problem, but I obviously have other issues going on here. It may have to do with the fact I have 3 computers hanging around the same modem. But - Progress! I should be able to hardwire the computer to the modem and still have it work yes? Thanks - KK
