luke (RL)
luke (RL)
Group: Power Developer
Visits: 5.6K
animagic (12/4/2019)
Luke, I sent you a PM. I already reported the Clipping Plane issue in this post: https://forum.reallusion.com/FindPost428115.aspx and also in FT #6458. I sincerely hope that this will also be fixed in the upcoming patch because it affects the use of cameras for large Clipping Plane ranges (i.e., you cannot set the maximum range of 1-99999). Yes, this one is on the list, will be fixed in the next patch
Snarp Farkle
Snarp Farkle
Visits: 3.6K
I can no longer use my laptop's 3TB USB drive as storage for my iClone custom folder since the iC7.7 update, all of the save "+" buttons, except for the Project button, are greyed out and not functional. I can confirm that this issue is directly caused by the iC7.7 update because I uninstalled iC7 then reinstalled using the "C:" drive for the custom folder and the save "+" buttons are now visible and functioning. Problem is that the laptop's hard drive is only a 237GB drive, so I can only put a few things in the custom folder to work on. Besides that I use the 3TB USB drive as a "go-between" to the desktop machine to keep both custom folders the same. This was all working fine prior to the iC7.7 update. On another note, I haven't bee able to use my Reallusion USB Drive for my desktop machine since February for the same reason... all of the save "+" buttons, except for the Project button, are greyed out and not functional. Since I had enough room on the "C:" drive I just gave up trying all the workarounds, after weeks of several unsuccessful attempts I just use the "C:" drive for my template and custom folders now. I have ordered a larger internal hard drive for the laptop so I can use the "C:" drive for storage on it as well as it appears that this issue will never be fixed.
FEEDBACK TRACKER
toystorylab
toystorylab
Last Active: 4 Months Ago
Posts: 4.6K,
Visits: 29.9K
luke (RL) (12/4/2019) Not only one definitely. if you encountered some serious issues due to this version, please pm me, thanksI did not install 7.7 (decided to keep working with 7.6) because of several issues reported on the forum, mostely some minor ones, but enough for me to wait for the next patch. So , i can't report issues because i simply do not use it to avoid trouble...
Last Active: 5 Months Ago
@Snarp Farkle: I wonder what causes your problem. I have 7.7 installed on my laptop with all content on an external drive and I can access it OK. On my PC I have all content on an internal drive other than C: and that works as well.
thebiz.movies
thebiz.movies
Posts: 2.1K,
Visits: 42.3K
Hi all, I cannot use the look at feature on attached or linked items which means I cant have a character look at items he is holding. Was this always the case? Seems like a pretty basic functionality. Anyone?
mark
Posts: 4.9K,
Visits: 16.7K
Is it with any particular avatar biz? Seems to work for me with DH and CC avatars.
Dragonskunk
Dragonskunk
Visits: 1.4K
thebiz.movies (12/8/2019) Hi all, I cannot use the look at feature on attached or linked items which means I cant have a character look at items he is holding. Was this always the case? Seems like a pretty basic functionality. Anyone?Been like that since 7.6 You can make the character looks at a cube and have the cube parented to what it is suppose to look at as a work around.
OOPS, I hope no-one saw the original...:blush:There is a new feature in the timeline to trim a clip, that I mistook for shortening and lengthening the clip to adjust the timing, which of course did not work...:unsure: It's all good now.  This is the disadvantage of having used an application for a long time... :Whistling:
primaveranz
primaveranz
Visits: 1.2K
Is this still broken for you? I am considering buying the Curve Editor but not if it doesn't work any more....
DavidinLA
DavidinLA
Visits: 471
I just tried it and it seems to be working. I'm not sure what was going wrong before. I'm going to close the ticket on it.
