Crazy Talk Animator 3.3.3007.1 ver we used dummy G2 Character Replacement problem
Posted By gvraju.666 8 Years Ago
Crazy Talk Animator 3.3.3007.1 ver we used dummy G2 Character...
jlittle
jlittle
Posts: 1.9K, Visits: 17.3K
You can create individual .png images for each sprite and angle and import/replace that angle with those images.
Use any paint or drawing program that creates .png files to create the sprite.
Jeff
gvraju.666
gvraju.666
Senior Member (419 reputation)Senior Member (419 reputation)Senior Member (419 reputation)Senior Member (419 reputation)Senior Member (419 reputation)Senior Member (419 reputation)Senior Member (419 reputation)Senior Member (419 reputation)Senior Member (419 reputation)
Last Active: 7 Years Ago
Posts: 16, Visits: 65
HELLO SIR
  THANK U
LAST 6 DAY S AGO U HAVE  GIVEN A ANSWER  FOR MY ISSUE  IT WAS CLEARED ..BUT WE HAVE A ANOTHER ISSUE  IN MIRROR
1-- WE START MIRROR IN 0 ANGLE IT IS WORKING
https://forum.reallusion.com/uploads/images/5c2e1f47-6d53-4ee7-9b2d-141f.jpg
2-- IN 270 ANGLE THE LEFT UPPER HAND SPRITE ..WHEN WE MIRROR IT .. RIGHT UPPER HAND SPRITE WHICH WAS MIRRORED  IS NOT VISIBLE IN 270 ANGLE IN COMPOSER MODE AND STAGE MODE
https://forum.reallusion.com/uploads/images/9b07ff46-b53f-4955-99e3-5cab.jpg
https://forum.reallusion.com/uploads/images/fed67ab6-73ad-4785-a30c-f6ff.jpg
3 -- IT APPEARS IN 90 ANGLE  RIGHT
https://forum.reallusion.com/uploads/images/94ef6ddf-b367-4f43-a2ad-45ff.jpg
THIS IS OUR  PROBLEM PLS GIVE A VALUABLE ANSWER  TO RECOVER  ...THAT PROBLEM SIR  PLS HELP US  SIR
 WE R WAITING FOR  U R ANSWER SIR  ...AS EARLY AS POSSIBLE
jlittle
jlittle
Without using/opening a copy of your character I would guess that the arm part is rotated to another angle thus showing a different sprite.
In Composer Mode, to check that the sprite is in the correct position, select the body part then open the Sprite editor and click on the Full Angles button. This will show the sprites for each angle for just that body part.
To check if the right sprite is showing in Stage Mode, select your character, rotate to position, then open the Runtime Composer.
Select the body part from the Runtime Composer character model and check that the angle showing matches the characters rotation angle and that the sprite showing is correct.
If the correct sprite is NOT showing, then use the 3D Motion Editor to rotate the arm to the correct position as I showed previously.
Jeff
gvraju.666
gvraju.666
hello sir thank u sir
we r not getting this  pls send a video file to us  pls sir
gvraju.666
gvraju.666
sir we r getting mirror problem sir in 270 when add a sprite to left it is not mirror at right..in 270 angle but it shows in 90 angle right  this main problem yesterday we posted sir
pls give video file to recover this problem sir
gvraju.666
gvraju.666
CRAZY TALK ANIMATOR G2 DUMMY CHARACTER 270 ANGLE MIRROR SPRITE PROBLEM
HELLO SIR
WE HAVE A ISSUE IN 270 ANGLE
https://forum.reallusion.com/uploads/images/486e9784-3019-4cc5-b25d-2e2f.jpg
https://forum.reallusion.com/uploads/images/980795d5-74e8-4659-a972-f4ce.jpg
AFTER THE LEFT UPPER HAND  SPRITE IN LEFT SIDE
https://forum.reallusion.com/uploads/images/31afe409-09f3-4a86-8c13-d49d.jpg
WHEN WE MIRROR TO RIGHT
https://forum.reallusion.com/uploads/images/6cb4ac57-71a6-4cb4-892f-8eb2.jpg
https://forum.reallusion.com/uploads/images/5af4635c-cbdd-497f-8c53-01f2.jpg
WE OR NOT GETTING THE SPRITE WHICH IS MIRROR TO RIGHT SIDE
BUT IT WAS SHOWING IN 90 ANGLE
https://forum.reallusion.com/uploads/images/25abac8f-e9b4-4e6f-9be2-9c85.jpg
SIR WE REQUEST U TO TELL US HOW TO RIG  IN 270 ANGLE ,PLS SEND US A VIDEO FILE.
WE ALREADY SEEN THE  CRAZY TALK TUTORIAL THE SPRITE REPLACEMENT IN  0 ANGLE PLS SEND US 270 ANGLE RIG VIDEO IN CRAZY TALK ANIMATOR 3  G2 CHARACTER
AND  {{{ IN STEP BY STEP CRAZY  TUTORIAL WE R NOT GETTING PROPER TUTORIAL PLS SEND US WITH URL YOUTUBE LINK}}}
gvraju.666
gvraju.666
crazy talk animator 3.3.3007.1  mirror problem in 270 angle as we posted last week
pls help us we r eagerly waiting for u r answer .. 270 mirror ..we need video tutorial with URL link of youtube
jlittle
jlittle
Attach the character with the issue here and I will look at it.
Jeff
gvraju.666
gvraju.666
sir the the problem in 270 angle  mirror issue
https://forum.reallusion.com/uploads/images/3f647d6d-186a-48db-8b08-cb73.jpg
https://forum.reallusion.com/uploads/images/99a47676-d107-4fef-b740-56eb.jpg
it is not mirroring
sir pls send us a reliable answer ..with video tutorial ...pls we requesting  u ...pls solve our problem
sir we r trying to  attached file  file...but file is not uploading in this reallusion forum ..tell that space problem how to recover it and how to send the file
jlittle
jlittle
Go to your profile page. On the left at the bottom there is a section called "Options"
Click on the "Edit Attachments".
Select and Delete attachments until you have room.
Jeff
