Why is motion live iphone so slow?
Posted By lucasfarleigh 7 Years Ago
Dan Miller
Dan Miller
Last Active: Today @ 4:16 AM
Posts: 374, Visits: 1.8K
Have you watched this video? The only difference is since you are connecting USB, you will need to turn the phone's WiFi off to get a local IP. Then use that IP in the same way as shown in the video and it should connect.
lucasfarleigh
lucasfarleigh
Veteran Member (894 reputation)Veteran Member (894 reputation)Veteran Member (894 reputation)Veteran Member (894 reputation)Veteran Member (894 reputation)Veteran Member (894 reputation)Veteran Member (894 reputation)Veteran Member (894 reputation)Veteran Member (894 reputation)
Posts: 20, Visits: 137
Ok got it, thanks, yes I have watched the video.
I did plug in the phone, I did forgot to reinstall the profile as I had iClone running
lucasfarleigh
lucasfarleigh
So all you need to do is use the personal hotspot with a usb so your using the PH to connect but it's a lot faster because it's actually a wired connection - make sure its wired otherwise it will still be rusty. You may need to download itunes for a wired hotspot connection
Posts: 9.2K, Visits: 22.1K
Actually, you don't need a PH at all with either wi-fi or USB -- those instructions are *very* misleading.
Just follow them but leave out that part and it will work fine (with good wi-fi it doesn't need the USB connection but not everyone is sitting right on top of their router as I am here).
Mike "ex-genius" Kelley
