Flash Character Animation Generator
Posted By Peter (RL) 15 Years Ago
perriced
perriced
Posted 14 Years Ago
Last Active: 12 Years Ago
Posts: 267, Visits: 846
Vidi, hi. Wonder if you can help? I follow what you're saying about exporting 2 frames of character as swf into Adobe/DrawPlus to edit sprite. I have DrawPlus. I also understand I need to open this as Keyframe Animation in DrawPlus.
The one thing I can't quite get is HOW TO SELECT JUST ONE OBJECT/PART of that character to edit it individually in DrawPlus. That only seems possible when I open as Drawing. I think...I know I'm missing something obvious.
thanks for any help
Dave
jlittle
jlittle
Posted 14 Years Ago
Posts: 1.9K, Visits: 17.3K
DrawPlus can not open swf files but can open svg files.
I use the Sothink SWF Decompiler which allows you to export the various objects from your 2 frame swf export into svg files.
You can then open the svg files in DrawPlus and edit.
Once you edit the files, export from DrawPlus as swf (via KeyFrame) and import back into CTA.
Jeff
perriced
perriced
Posted 14 Years Ago
Jeff, thanks. Works like a charm. Exactly what I was looking for. But...is there a good "freebie" flash decompiler that you or anyone out there can recommend? again, thanks, Dave
PS I see in another thread that you've already covered this ground quite thoroughly (and Vidi clarified that DrawPlus cannot edit swf), so thanks for reiterating here. And, I see that Sothink is certainly cheaper than Adobe. Still, can we go cheaper still? that is free? Or am I asking too much?
jlittle
jlittle
Posted 14 Years Ago
I had looked around some and that is when I came across Sothink which did everything I wanted.
There are a few others but you'd have to check that they will export the resources.
You might want to look at FlashDecompiler which is a little cheaper.
Jeff
perriced
perriced
Posted 14 Years Ago
Jeff, thanks again for your further suggestions.  I'll consider buying one or the other; it would certainly broaden my range.  I wonder if Reallusion has considered incorporating--somehow???--this capability of editing flash sprites right into the new version of CTA????
Dave
jlittle
jlittle
Posted 14 Years Ago
Dave,
I haven't used the "FlashDecompiler" so I would recommend trying out the free version first.
You might look around some more on the internet for there are probably others I missed.
Putting full fledged vector editing into CTA would make the program larger, more complex, and more expensive. I'd rather have a few built in basic tools and be able to pick the editors (vector/photo) of my choice as 3rd party external apps.
Jeff
perriced
perriced
Posted 14 Years Ago
Jeff, again thanks for help. Yes, actually just after I sent that suggestion off, I realized it might make for a pretty hefty program. And simplicity is, after all, one of CTA beauties, yes?
thanks, Dave
