[CC3 to Unity] Auto-Setup Script Download & Update History
Posted By Miranda (RL) 7 Years Ago
Miranda (RL)
Miranda (RL)
Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)
Posts: 1.8K, Visits: 11.2K
You can download the auto-setup tool "Character Creator & iClone Auto Setup" from HERE.
  • From v1.01, the file format is changed from .zip to .exe.  You get the same folders after executing the installation file, and copy the folders for auto setup.
  • Once you update Character Creator to 3.1, and update iClone to 7.6 or any version above, an update notice will prompt upon program startup if there is a new release of the auto-setup tool.
Source Code (July 14th, 2021)
Source code for Auto Setup plugin was released to the public since July 14th, 2021. You can get a hold of the code and customize it according to your needs. Please visit the forum for more details.
Official 1.1 (Sept 2nd, 2020) - Compatible with CC3.31, iClone 7.81
Please read THIS post for more information.
Official 1.02 (June 8th, 2020) - Compatible with CC3.2, iClone 7.7
  • Added: Compatible with Unity 2019.2 and 2019.3.
Official 1.01 (Aug 29th) - Compatible with CC3.1, iClone 7.6
  • Added: Shader assignment on props exported from iClone is now automated.
  • Enhanced: Linked textures in CC do not associate correctly when exported to Unity.  A Json file is provided to fix this inconsistency and apply the textures correctly onto the material.
  • Enhanced: Support for multiple LOD meshes bound onto the same skeleton.
  • Enhanced: Removed excessive glossiness on the character's skin material in Unity.
  • Enhanced: Animation only FBX files will automatically import as humanoid motions.
  • Known Issue: Unity Auto Setup does not refresh materials upon completion.  One must click on the individual material balls in order to refresh the visuals.
Beta 2.0  (March 19th) - Compatible with CC3.04 or above
  • Added: Skin material will be supplemented with a Detail Map along with proper subsurface scattering (SSS) settings. (For HDRP Rendering Pipeline only)
    https://forum.reallusion.com/uploads/images/d179d9f4-5e5f-4cc7-a751-27a8.jpg
    https://forum.reallusion.com/uploads/images/790ce965-c9de-4703-b136-b7bc.jpg
  • Added: Assign the equivalent UE materials based on what was deployed in CC3:
    • Traditional -> Specular
    • PBR -> MatellicAlpha, Roughness, Matellic
  • Fixed: Auto-processing checkbox is not recording its unchecked/disabled status. (Related issue)
  • Fixed: Automatically change the Color Space of project to be Linear after auto processing. (Related issue) -- we shall recommend users to choose Linear colorspace, instead of forcing them to do
Beta 1.3 (Feb. 19th, 2019) - Compatible with CC3.03 or above Beta 1.2 (Jan. 7th, 2019) - Compatible with CC3.03 or above
  • Fixed: Textures not belong to CC_Assets are relocated and moved unexpectedly. (Related issue)
Beta 1.1 (Dec. 24th, 2018) - Compatible with CC3.03 or above
  • Added: HDRP and LWRP auto-settings script.
    https://forum.reallusion.com/uploads/images/1f10bd2d-32c4-4641-ae20-3111.png
  • Fixed: Cornea became white after performing auto-setup. (Related issue)
    *Solution: When there is no diffuse map on the cornea, the Auto-Setting script will change the rendering mode from opaque to transparent, and the opacity value will be properly applied.
  • Enhanced: Automatically set up the rendering mode of hair to be "Fade" to have better visual quality.
Beta 1.0 (Nov. 30th, 2018)
  • Initial version
Special Notice & FAQ
Welcome to share your experience with us, thank you :)
Threaded View
Threaded View
Forum Post [CC3 to Unity] Auto-Setup Script Download & Update History By Miranda (RL) ( 7 Years Ago )
Forum Post Well, this is exactly what i needed but it doesn't work for the fact... By Dorothy Jean ( 7 Years Ago )
Forum Post Thanks for the script and tutorial Miranda. I will try this a soon as... By Jfrog ( 7 Years Ago )
Forum Post The script looks promising! Does it also work with Game Base and... By Kareeem ( 7 Years Ago )
Forum Post [quote][b]Kareeem (12/7/2018)[/b][hr]The script looks promising! Does... By Miranda (RL) ( 7 Years Ago )
Forum Post Hello Miranda, Tobias here from Descendent Studios, Austin TX.... By manaland ( 7 Years Ago )
Forum Post [quote][b]manaland (12/8/2018)[/b][hr] - Is the importer script... By Miranda (RL) ( 7 Years Ago )
Forum Post Hi everyone, The tutorial of "Setting Up LOD for CC3 Characters in... By Miranda (RL) ( 7 Years Ago )
Forum Post I seem to have run into bug: 1.Drag the exported folder which... By Ryan Hayle ( 6 Years Ago )
Forum Post [quote][b]rjhayle (2/24/2019)[/b][hr]I seem to have run into bug:... By Miranda (RL) ( 6 Years Ago )
Forum Post Can you specify what "folder" you deleted? 1. I drag in my NPC... By Ryan Hayle ( 6 Years Ago )
Forum Post Hi rjhayle, What Unity version did you use? We are unable to... By Miranda (RL) ( 6 Years Ago )
Forum Post Hi Miranda, From the first page of this post the new download script... By Jfrog ( 6 Years Ago )
Forum Post [quote][b]Jfrog (3/4/2019)[/b][hr]Hi Miranda, From the first page of... By Miranda (RL) ( 6 Years Ago )
Forum Post Thank you for the update and the quick reply Miranda. By Jfrog ( 6 Years Ago )
Forum Post I followed the video and used the script to export a Game Base... By sunrisebacon ( 7 Years Ago )
Forum Post [quote] I followed the video and used the script to export a Game... By Dorothy Jean ( 7 Years Ago )
Forum Post Hi Kareeem and gregor.heinze, There will be some tutorials coming up,... By Miranda (RL) ( 7 Years Ago )
Forum Post Hello Miranda! Thank you for this great update and also for the new... By manaland ( 7 Years Ago )
Forum Post [quote][b]manaland (12/14/2018)[/b][hr]Hello Miranda! Thank you for... By Miranda (RL) ( 7 Years Ago )
Forum Post [quote]Tell your great Team to take all the time they need. Better... By brent_114049 ( 7 Years Ago )
Forum Post Or, if you're taking suggestions for future development, what I would... By brent_114049 ( 7 Years Ago )
Forum Post Hi Brent, Thanks for your feedback and clear description. The... By Miranda (RL) ( 7 Years Ago )
Forum Post To answer Mohab Rizkallah's comments form Tutorial - Setting Up LOD... By Miranda (RL) ( 7 Years Ago )
Forum Post [quote][b]Miranda (RL) (12/17/2018)[/b][hr]To answer Mohab Rizkallah's... By The Mohab ( 7 Years Ago )
Forum Post Any idea if the CC·export will address this issue and therefore we... By davidaranzabal ( 7 Years Ago )
Forum Post Maya?! It's a joke? When I prepaid CC3 in august nobody said a word... By Alexxander ( 7 Years Ago )
Forum Post Hi Mohab, davidaranzabal, and Alexxander, Please be noted that this... By Miranda (RL) ( 7 Years Ago )
Forum Post That's good news! By Alexxander ( 7 Years Ago )
Forum Post [quote][b]Miranda (RL) (12/18/2018)[/b][hr]Hi Mohab, davidaranzabal,... By davidaranzabal ( 7 Years Ago )
Forum Post Clear mouth bone when u setup mecanim avatar in Unity3D. By Alexxander ( 7 Years Ago )
Forum Post Hi everyone, A new version of Auto-Settings Script is available to... By Miranda (RL) ( 7 Years Ago )
Forum Post [quote][b]Miranda (RL) (12/24/2018)[/b][hr]Hi everyone, A new... By Ryan Hayle ( 6 Years Ago )
Forum Post [quote][b]rjhayle (1/3/2019)[/b][hr] This... By Miranda (RL) ( 6 Years Ago )
Forum Post [quote][b]Miranda (RL) (1/4/2019)[/b][hr][quote][b]rjhayle... By Miranda (RL) ( 6 Years Ago )
Forum Post Thank you, that's great news! By Ryan Hayle ( 6 Years Ago )
Forum Post Hi everyone, The fourth tutorial just released >> Importing... By Miranda (RL) ( 6 Years Ago )
Forum Post Hi, I tried exporting a character using the tutorial provided. I'm on... By marc_655066 ( 7 Years Ago )
Forum Post Hi Marc, we will check it, and get back to you on Wednesday, thanks!... By Miranda (RL) ( 7 Years Ago )
Forum Post Hi Marc, Due to the rendering mode of both hair and scalp are fade,... By Miranda (RL) ( 6 Years Ago )
Forum Post I struggled for a long time with making Reallusion character hair look... By brent_114049 ( 6 Years Ago )
Forum Post [quote][b]brent_114049 (1/3/2019)[/b][hr]I struggled for a long time... By Miranda (RL) ( 6 Years Ago )
Forum Post RE: [CC3 to Unity] Auto-Setup Script Download & Update History By firefighter1531 ( 6 Years Ago )
Forum Post this is what I get on import I tried 2018.02 f1,2018.31f1,2019b By firefighter1531 ( 6 Years Ago )
Forum Post [quote][b]firefighter1531 (1/13/2019)[/b][hr] this is what I get on... By Miranda (RL) ( 6 Years Ago )
Forum Post The top one in the folder which would be the hdr high I did not try... By firefighter1531 ( 6 Years Ago )
Forum Post [quote][b]firefighter1531 (1/15/2019)[/b][hr]The top one in the folder... By Miranda (RL) ( 6 Years Ago )
Forum Post Yes I downloaded the 1.2 version as soon as I installed it it said... By firefighter1531 ( 6 Years Ago )
Forum Post this is after downloading the one you said which is the same as I had... By firefighter1531 ( 6 Years Ago )
Forum Post [quote][b]firefighter1531 (1/15/2019)[/b][hr]this is after downloading... By Miranda (RL) ( 6 Years Ago )
Forum Post so have got that straight thank you for that now I am following the... By firefighter1531 ( 6 Years Ago )
Forum Post here is the mat list not sure if this is problem By firefighter1531 ( 6 Years Ago )
Forum Post Hi firefighter1531, I sent you a private message yesterday to ask for... By Miranda (RL) ( 6 Years Ago )
Forum Post Hi, I know the readme says "Put your character files in this folder",... By bloodzseekerz ( 6 Years Ago )
Forum Post [quote][b]bloodzseekerz (1/20/2019)[/b][hr]Hi, I know the readme says... By Miranda (RL) ( 6 Years Ago )
Forum Post Im trying to get this to work in Unity on the android platform. but it... By Steelbound ( 6 Years Ago )
Forum Post [quote][b]Steelbound (1/22/2019)[/b][hr]Im trying to get this to work... By Miranda (RL) ( 6 Years Ago )
Forum Post I just tried the export from CC3.03 to Unity3D 2018.3.3f1 with HDRP... By michael.pickering ( 6 Years Ago )
Forum Post [quote][b]michael.pickering (2/1/2019)[/b][hr]I just tried the export... By Miranda (RL) ( 6 Years Ago )
Forum Post Hi Miranda, Thanks for the response! Just an update that I managed to... By michael.pickering ( 6 Years Ago )
Forum Post Just as a further note on the import problem, it appears not to be... By michael.pickering ( 6 Years Ago )
Forum Post Hi Michael, Thanks for the updates! We will try to duplicate this... By Miranda (RL) ( 6 Years Ago )
Forum Post [quote][b]michael.pickering (2/5/2019)[/b][hr]Just as a further note... By Miranda (RL) ( 6 Years Ago )
Forum Post I can't seem to use the appearance editor on the game eyes is there a... By Jbowdoin ( 6 Years Ago )
Forum Post [quote][b]Jbowdoin (2/11/2019)[/b][hr]I can't seem to use the... By Miranda (RL) ( 6 Years Ago )
Forum Post lol I ask because the tutorials said to uses game and teeth eyes 3... By Jbowdoin ( 6 Years Ago )
Forum Post [quote][b]Jbowdoin (2/12/2019)[/b][hr]lol I ask because the tutorials... By Miranda (RL) ( 6 Years Ago )
Forum Post y[quote][b]Miranda (RL) (2/12/2019)[/b][hr][quote][b]Jbowdoin... By Jbowdoin ( 6 Years Ago )
Forum Post [quote][b]Jbowdoin (2/12/2019)[/b][hr] yeah the second video at 1:15... By Miranda (RL) ( 6 Years Ago )
Forum Post ok thanks will the editor support them wen the update for CC3 skin... By Jbowdoin ( 6 Years Ago )
Forum Post [quote][b]Jbowdoin (2/13/2019)[/b][hr]ok thanks will the editor... By Miranda (RL) ( 6 Years Ago )
Forum Post The CC_Character_Auto_Settings_Script.dll is forcing Unity... By wbl ( 6 Years Ago )
Forum Post Hi wbl, This is the current settings because the result with Linear... By Miranda (RL) ( 6 Years Ago )
Forum Post The information and videos have been extremely helpful. The CC3... By Dan Miller ( 6 Years Ago )
Forum Post Disregard, it works great on the Timeline. I did it wrong. So overall... By Dan Miller ( 6 Years Ago )
Forum Post Got it, thanks for getting back, danmiller. By Miranda (RL) ( 6 Years Ago )
Forum Post [quote][b]Miranda (RL) (3/16/2019)[/b][hr]Got it, thanks for getting... By Dan Miller ( 6 Years Ago )
Forum Post I usually right click in the animation track (be careful not selecting... By Jfrog ( 6 Years Ago )
Forum Post Hi everyone, Script Beta 2.0 is available now. Please find the... By Miranda (RL) ( 6 Years Ago )
Forum Post Hi everyone, Some features you requested have been implemented to the... By Miranda (RL) ( 6 Years Ago )
Forum Post Hi Miranda, Thanks to you and the team for all the work on the Unity... By michael.pickering ( 6 Years Ago )
Forum Post Hi Mike, Thanks for addressing out this issue! The current situation... By Miranda (RL) ( 6 Years Ago )
Forum Post Hi Miranda, There's one more issue that I've noticed that needs to be... By michael.pickering ( 6 Years Ago )
Forum Post Hi Mike, The Delete Hidden Mesh function is written in the online... By Miranda (RL) ( 6 Years Ago )
Forum Post Hi Miranda, My expectation is simple: make it clear that the... By michael.pickering ( 6 Years Ago )
Forum Post [quote][b]michael.pickering (4/22/2019)[/b][hr]Hi Miranda, My... By Miranda (RL) ( 6 Years Ago )
Forum Post Hi, I'm having a couple of issues using the unity importer script.... By e1_scheer ( 6 Years Ago )
Forum Post [quote][b]e1_scheer (4/23/2019)[/b][hr]Hi, I'm having a couple of... By Miranda (RL) ( 6 Years Ago )
Forum Post Hi Miranda, Thanks for the answers first of all, they definitely... By e1_scheer ( 6 Years Ago )
Forum Post [quote][b]e1_scheer (5/31/2019)[/b][hr] Hi Miranda, Thanks for the... By Miranda (RL) ( 6 Years Ago )
Forum Post What about Unity 2019 and HDRP 6.5.3? Is support planned? There are... By greluk.a ( 6 Years Ago )
Forum Post [quote][b]greluk.a (5/22/2019)[/b][hr] What about Unity 2019 and HDRP... By Miranda (RL) ( 6 Years Ago )
Forum Post Using Beta 2 version of the import script for Unity, and Unity... By glugsolro ( 6 Years Ago )
Forum Post [quote][b]glugsolro (5/23/2019)[/b][hr]Using Beta 2 version of the... By Miranda (RL) ( 6 Years Ago )
Forum Post Here is the image again. By glugsolro ( 6 Years Ago )
Forum Post Hi glugsolro, To fix the transparency sorting issues in Unity, the... By Miranda (RL) ( 6 Years Ago )
Forum Post Thanks for the information Miranda. I'm however not using HDRP as... By glugsolro ( 6 Years Ago )
Forum Post [quote][b]glugsolro (5/31/2019)[/b][hr]Thanks for the information... By Miranda (RL) ( 6 Years Ago )
Forum Post Hi, I'm wondering how I'm supposed to use the generated LODs of a... By andgeno ( 6 Years Ago )
Forum Post [quote][b]andgeno (6/23/2019)[/b][hr]Hi, I'm wondering how I'm... By Miranda (RL) ( 6 Years Ago )
Forum Post [quote][b]Miranda (RL) (6/24/2019)[/b][hr][quote][b]andgeno... By andgeno ( 6 Years Ago )
Forum Post For those who get all material pink and purple. Remember to change the... By lidong19980608 ( 6 Years Ago )
Forum Post can you please expand on what this means? What is a "material ball"?... By drew_927096 ( 6 Years Ago )
Forum Post [quote][b]drew_927096 (9/18/2019)[/b][hr]can you please expand on what... By Miranda (RL) ( 6 Years Ago )
Forum Post Hi, I like the script, it speeds things quite nicely in 2019.2 HDRP.... By Steelsky ( 6 Years Ago )
Forum Post Steelsky: This will be a perpetual problem because Unity updates so... By Scyra ( 6 Years Ago )
Forum Post Hi Scyra, Thanks for the reply. Respectfully, I know that can be... By Steelsky ( 6 Years Ago )
Forum Post Gotcha. I do see your point. By Scyra ( 6 Years Ago )
Forum Post Is there a way to properly turn off auto-processing? I need to change... By jdeep6 ( 6 Years Ago )
Forum Post Hello! To turn off the auto-processing script, go to the Top Menu... By Miranda (RL) ( 6 Years Ago )
Forum Post Thank you but I'm aware of that. The issue is that it checks itself... By jdeep6 ( 6 Years Ago )
Forum Post May you specify the Unity version you are using? Can you record a... By Miranda (RL) ( 6 Years Ago )
Forum Post Hi, I'm trying to use the HDRP auto setup script, but the only way to... By qbgroupapp ( 5 Years Ago )
Forum Post Hi Marco, Can you screenshot the Console page?... By Miranda (RL) ( 5 Years Ago )
Forum Post Here it is, does not seem to be something critical in the console log.... By qbgroupapp ( 5 Years Ago )
Forum Post I need to find a solution, it is getting urgent for me. Is there... By qbgroupapp ( 5 Years Ago )
Forum Post I successfully imported characters from CC3 into Unity 2019.1.14f1... By ptrefall ( 5 Years Ago )
Forum Post Along the lines of the question above. When is the Auto-Setup tool... By astgeorge ( 5 Years Ago )
Forum Post [quote][b]astgeorge (2/14/2020)[/b][hr]Along the lines of the question... By Miranda (RL) ( 5 Years Ago )
Forum Post My CC3 characters exhibit severe joint deformations when playing... By markrrand ( 5 Years Ago )
Forum Post Hi markrrand, Sorry for the late response. It seems to be a known... By Miranda (RL) ( 5 Years Ago )
Forum Post Posted on Feedback tracker concurrent with the original post. Have not... By markrrand ( 5 Years Ago )
Forum Post [quote][b]markrrand (3/13/2020)[/b][hr]Posted on Feedback tracker... By Miranda (RL) ( 5 Years Ago )
Forum Post Currently, the tool for importing CC3 and iClone .fbx files into... By mark_931256 ( 5 Years Ago )
Forum Post The reason why the Auto Setup no longer works with Unity 2019.3 that... By chris_466129 ( 5 Years Ago )
Forum Post I hope guys from Reallusion will update the plugin for Unity to... By denisionin ( 5 Years Ago )
Forum Post Hi everyone! Sorry for the long long waiting. Dev Team promised to... By Miranda (RL) ( 5 Years Ago )
Forum Post I hope so too! :) By Jfrog ( 5 Years Ago )
Forum Post [quote][b]denisionin (4/28/2020)[/b][hr]I hope guys from Reallusion... By Miranda (RL) ( 5 Years Ago )
Forum Post [quote][b]denisionin (4/28/2020)[/b][hr]I hope guys from Reallusion... By jasonweise ( 5 Years Ago )
Forum Post I am also waiting for the update. A bit disappointed with the time in... By Jfrog ( 5 Years Ago )
Forum Post Hi,I'm trying to use Auto Import plugin... By messer262a2 ( 5 Years Ago )
Forum Post Hello, The CC3 character has to be exported directly into the CC... By Dan Miller ( 5 Years Ago )
Forum Post Hi, I did everything exactly as it was shown in the youtube tutorial.... By messer262a2 ( 5 Years Ago )
Forum Post Hmm, I don't know what the issue is. If you find the answer I would be... By Dan Miller ( 5 Years Ago )
Forum Post The problem is that Albedo for all materials is set to black after... By messer262a2 ( 5 Years Ago )
Forum Post Hi messer262a2, This is Miranda from Reallusion. The Albedo texture... By Miranda (RL) ( 5 Years Ago )
Forum Post Hi Miranda, The Unity project is basic HDRP project with no changes.... By messer262a2 ( 5 Years Ago )
Forum Post Hi, I uploaded the Unity project and exported CC3 character. The... By messer262a2 ( 5 Years Ago )
Forum Post Thank you! We are checking the issue now. [quote][b]messer262a2... By Miranda (RL) ( 5 Years Ago )
Forum Post Hi everyone, Unity Auto Setup v1.02 just released to be... By Miranda (RL) ( 5 Years Ago )
Forum Post This is great news! Thank you Miranda and thanks you to the Reallusion... By Jfrog ( 5 Years Ago )
Forum Post [quote][b]messer262a2 (5/28/2020)[/b][hr]Hi, I uploaded the Unity... By luke (RL) ( 5 Years Ago )
Forum Post Hello, I tried the new autosetup, it doesn't work in Unity 2019.3... By messer262a2 ( 5 Years Ago )
Forum Post @Miranda Hi Miranda. Do you have any ETA when we will have a version... By Jfrog ( 5 Years Ago )
Forum Post Hi Jfrog and others, We are going to have a new version along with... By Miranda (RL) ( 5 Years Ago )
Forum Post @Miranda, Thanks for keeping us in the loop Miranda. By Jfrog ( 5 Years Ago )
Forum Post [quote][b]Miranda (RL) (7/16/2020)[/b][hr]Hi Jfrog and others, We are... By denisionin ( 5 Years Ago )
Forum Post [quote][b]denisionin (8/3/2020)[/b][hr] Is there any update on this?... By Miranda (RL) ( 5 Years Ago )
Forum Post Will there be support for Unity 2019.4.LTS in the next version of this... By synthetics ( 5 Years Ago )
Forum Post [quote][b]avalonsutra (7/28/2020)[/b][hr]Will there be support for... By Miranda (RL) ( 5 Years Ago )
Forum Post [quote][b]Miranda (RL) (7/29/2020)[/b][hr][quote][b]avalonsutra... By synthetics ( 5 Years Ago )
Forum Post Hello ! I already tested Unity Autosetup ( for me the most important... By Sekker2k4 ( 5 Years Ago )
Forum Post My test with CC3 inside Unity is being nice, some bugs can be... By FabricioAlencar ( 5 Years Ago )
Forum Post @FabricioAlencar, It looks really good! Is this picture taken from... By Jfrog ( 5 Years Ago )
Forum Post @Miranda so I did some more testing with Unity 2019.4 today... First... By synthetics ( 5 Years Ago )
Forum Post You need to apply DIffusion Profile to the SSS shader and make sure... By denisionin ( 5 Years Ago )
Forum Post Hi avalonsutra, We were aware of this issue, and made a note on the... By Miranda (RL) ( 5 Years Ago )
Forum Post Hello, It's fixed in version 1.1. There is no need to manually change... By Miranda (RL) ( 5 Years Ago )
Forum Post So is it a plan to have unity 2019.4.7f1 LTS being apart of the new... By deidrereaystudios ( 5 Years Ago )
Forum Post I also have problems in Exporting and Auto creating character in Unity... By tvwk2013 ( 5 Years Ago )
Forum Post There's a bug in 1.02 with Unity 2020.x, if you have the tick box... By chris_466129 ( 5 Years Ago )
Forum Post I'm not following all 17 page of this thread, but why can't I download... By peterbehere ( 5 Years Ago )
Forum Post [quote][b]peterbehere (9/27/2020)[/b][hr]I'm not following all 17 page... By Peter (RL) ( 5 Years Ago )
Forum Post Ok, I see. I am using Chrome, but there is no indication that the... By peterbehere ( 5 Years Ago )
Forum Post Hi... If you are still having problems, please use the direct download... By Peter (RL) ( 5 Years Ago )
Forum Post Hello! Correct me if i am wrong but there will not be any Auto set up... By coach1 ( 5 Years Ago )
Forum Post Hello coach1, The next update to support this version will be... By Miranda (RL) ( 5 Years Ago )
Forum Post Is there any way to work around to suggest for 2019.4 LTS even if i... By coach1 ( 5 Years Ago )
Forum Post Hi, After carefully read everything here, unfortunately there is no... By csablazar ( 5 Years Ago )
Forum Post Hello csablazar, Try not to tick Embed Textures checkbox in Export... By Miranda (RL) ( 5 Years Ago )
Forum Post Hello Miranda, I have recently joined this community I have had a... By luke.vstone ( 5 Years Ago )
Forum Post totally agree. i am sending the pictures from CC3 to clients and the... By coach1 ( 5 Years Ago )
Forum Post Hi — can you please confirm that the next release of this utility will... By jrlamar ( 5 Years Ago )
Forum Post Hi — can you please confirm that the next release of this utility... By jrlamar ( 5 Years Ago )
Forum Post would like to have a support for 2020 & 2021 HDRP :) i been revisiting... By Lionious ( 5 Years Ago )
Forum Post w By MuriithiNyaga ( 5 Years Ago )
Forum Post Apparently Daz can figure this out ...... By jrlamar ( 5 Years Ago )
Forum Post @Miranda Hi Miranda, We are in 2021 and we still don't have any... By Jfrog ( 4 Years Ago )
Forum Post Yes, that's what I thought too. Had tested the bridge with 2020.1.8f1... By cognos ( 4 Years Ago )
Forum Post [quote][b]jrlamar (12/21/2020)[/b][hr]Apparently Daz can figure this... By Sekker2k4 ( 4 Years Ago )
Forum Post Dear Reallusion: I have spent hundreds of dollars on your software. I... By jrlamar ( 4 Years Ago )
Forum Post [quote][b]jrlamar (1/31/2021)[/b][hr]Dear Reallusion: I have spent... By coach1 ( 4 Years Ago )
Forum Post Sitting here completely confused.. How can reallusion not even answer... By deidrereaystudios ( 4 Years Ago )
Forum Post Yes i have CC3 for a year... i am Unity developer. and i am so... By Sekker2k4 ( 4 Years Ago )
Forum Post I have to agree with a lot of the points being raised about the... By e1_scheer ( 4 Years Ago )
Forum Post Thank you all for the feedback. We do understand the frustration... By Peter (RL) ( 4 Years Ago )
Forum Post Wow, an official acknowledgement! And only after almost 4 months of... By jrlamar ( 4 Years Ago )
Forum Post Thanks Peter. By Jfrog ( 4 Years Ago )
Forum Post Thanks Peter. As i tried to state this really is all people need is to... By deidrereaystudios ( 4 Years Ago )
Forum Post [quote][b]Peter (RL) (2/15/2021)[/b][hr]Thank you all for the... By Sekker2k4 ( 4 Years Ago )
Forum Post What we need is an official statement regarding upcoming... By cognos ( 4 Years Ago )
Forum Post Honestly I agree with so much of what Cognos said. Unity is literally... By deidrereaystudios ( 4 Years Ago )
