OFFICIAL iClone 7.2 Issues Thread
Posted By Peter (RL) 9 Years Ago
Rated 1 star based on 1 vote.
3
4
5
6
11
TonyDPrime
TonyDPrime
Distinguished Member (13.4K reputation)Distinguished Member (13.4K reputation)Distinguished Member (13.4K reputation)Distinguished Member (13.4K reputation)Distinguished Member (13.4K reputation)Distinguished Member (13.4K reputation)Distinguished Member (13.4K reputation)Distinguished Member (13.4K reputation)Distinguished Member (13.4K reputation)
Posts: 3.4K, Visits: 12.4K
4u2ges (2/9/2018)
TonyDPrime (2/9/2018)
This is a follow up on my earlier post regarding overlapping textures with opacity masking out.  In this case a Daz Genesis hair brought in through 3DXchange...
iClone 7 has a hard time showing what is behind one piece of hair shaped by an opacity map when there is another piece of hair shaped by an opacity map behind it.
It has difficulty reconciling the overlap of 2 or more "alpha/opacity/masked/transparency" textures.
Try minimizing viewport to smallest possible size and render. Is the result the same?
HOLY SHYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYX!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
That actually made a difference!
OMG - The ol' resize the screen maneuver strikes again.
THANK YOU 4U2GES!!!!
It didn't actually eliminate the problem, but it does drastically minimize it.  Some of the hair looks darker and pixelated, but not too noticeable.
Fascinating....almost like, if you can 'hide' the pixelation from the screen, then iClone can't see it and won't render it.
And you can hide it by making the viewport smaller through pulling the timeline towards the top of the screen.
So weird, but really amazing that it works this way.  Wondering if this is actually a NVidia driver issue revealed through iClone.
Well, developers can take note of the fact that viewport size adjustment does impact how iClone renders pixelation occurring with overlapping opacity masked textures (ie Daz hair with multiple overlapping textured pieces).
Really appreciate that help, 4U2ges!
Posts: 5.3K, Visits: 16.8K
TonyDPrime
TonyDPrime
Here is 1 piece:
https://forum.reallusion.com/uploads/images/4949654b-6250-4530-861c-f209.jpg
Now, I add a 2nd piece of the hair, so there are 2 pieces of hair stacked, both having an opacity map giving it shape.
On Viewport there is a moving flicker where iClone is trying to reconcile:
https://forum.reallusion.com/uploads/images/ca31d501-7015-4383-af9b-d5e8.jpg
Here is a 'Preview' render:
https://forum.reallusion.com/uploads/images/74739c36-0630-4039-9c27-548a.jpg
A Final Render @ 1080p looks the same as a Preview at 1080p.
Then one at UHD, 2160p
https://forum.reallusion.com/uploads/images/e7972a7d-ea17-4fde-9ec5-b6d6.jpg
You can use the "Alpha Threshold" slider in Material Settings for each texture to try and 'fix' the issue, but it then makes the hair look blocky and pixelated itself, so it looks bad :crying:
https://forum.reallusion.com/uploads/images/1152a37a-4db5-4495-b717-d522.jpg
TonyDPrime
TonyDPrime
I am investigating an issue with Dan Genesis Hair that comes in as multiple pieces.
I was assuming disappearing and flickering hair pieces was due to camera clipping, but now am finding that if individualized there is no issue with the camera focusing on it at any zoom level.
Seems to be a combination of overlapping textures with transparent alpha-opacity channels that iClone has trouble with...
Will update on findings.
thedirector1974
thedirector1974
Distinguished Member (7.2K reputation)Distinguished Member (7.2K reputation)Distinguished Member (7.2K reputation)Distinguished Member (7.2K reputation)Distinguished Member (7.2K reputation)Distinguished Member (7.2K reputation)Distinguished Member (7.2K reputation)Distinguished Member (7.2K reputation)Distinguished Member (7.2K reputation)
Posts: 783, Visits: 5.2K
thedirector1974 (2/8/2018)
The sliders are not the limit. You can put any value you want in the boxes where the numbers are. Sorry for my bad english. Hope you understand, what I want to say ... :)
Thanks Direx.  I tried again and the sliders are the min-max.  I tried inputting different #s in all of the sliders, but it won't go beyond the slider max values.  Does it work for you?
I know in Faceware and CC2 there are parameters with sliders that you can type in a number greater or less than the slider min-max, but in this case with DOF, the sliders seem to in fact be the min-max you can type in...Oh well....
I'll look into it as soon as get back home ... (Monday)
Direx
Posts: 8.2K, Visits: 26.5K
raxel_67 (2/7/2018)
Undo is not working again in 7.2
I noticed that to, but I think it was a corrupted session.  It worked again after restarting iClone.
Are you seeing that, too?  Or is it 100% broken for you?
(Still should be fixed, but might be difficult for them to find the root cause.)
TonyDPrime
TonyDPrime
(PS - as a native English speaker I would say your written English is excellent!...)
thedirector1974
thedirector1974
TonyDPrime
TonyDPrime
Never really played with DOF until now, and it seems kind of weak on closeups.   In Daz or Octane, for example, you can bring a significant blur vs sharpness in a very small geographic space via an aperture /F-Stop control.
But iClone's seems to only gradually spread it out over a larger geographic space.  I find that no matter what camera type, lens size, mm...whatever, and no matter what slider settings for DOF I use, it doesn't matter.
You can only spread a DOF blur so much, and it's not very much at all.  Just a touch of blur difference for smaller spaces.
Anyone else notice this?  Like the Blur between the colored DOF regions should be able to be greater.  Like a REALLY  heavy focus and then STRONG blur, in a few inches, let's say, if the objects were real world...
I'll just throw it in Feedback Tracker as a request, but just figured I'd see thoughts on this first.
Posts: 9.2K, Visits: 22.1K
Works for me (just tried a PNG export, which is the only export anyone should be using anyway).
3
4
5
6
11
