OFFICIAL iClone 7.2 Issues Thread
Posted By Peter (RL) 9 Years Ago
Rated 1 star based on 1 vote.
Posts: 23.1K, Visits: 36.6K
Dear iClone Users,
It's that time again when we have another new iClone 7 update and need your continued assistance to help us track down any remaining bugs, glitches or other annoying issues.
iClone 7.2 adds several exciting new features and also comes a number of important fixes and enhancements. It also introduces the arrival of the Popcorn FX plugin.
Important: If you do find any bugs, issues or glitches in the 7.2 update, please can you report them first in the Feedback Tracker. Then feel free to discuss the issues in this thread. However do make use of the Feedback Tracker first to log the issue.
As always it will help us greatly if we can keep all outstanding issue discussion in the one place (this thread). This will help the development team keep track of any problems.
Please do try to provide your full system specifications and a detailed description of the problem when reporting issues. If you can provide steps so we can try and reproduce the problem this will be even better.
Many Thanks. Smile
Threaded View
Threaded View
Forum Post OFFICIAL iClone 7.2 Issues Thread By Peter (RL) ( 9 Years Ago )
Forum Post I'm looking for confirmation on this before I post it in feedback... By Cary B ( 9 Years Ago )
Forum Post I was watching the video Tut by RL on Timeline enhanced features. I... By Alien Maniac ( 9 Years Ago )
Forum Post Never mind, I figured out that the issue I mentioned above is related... By Cary B ( 9 Years Ago )
Forum Post There is an issue with HDR Bloom - Bloom rings Basically when you add... By TonyDPrime ( 9 Years Ago )
Forum Post I have a render issue like we had on the beta 7.0 test. Depending on... By mtakerkart ( 9 Years Ago )
Forum Post I cannot use 7.2 patch. Direct puppet is the tool I have used most.... By rogwen ( 8 Years Ago )
Forum Post I have posted this issue in feedback tracker. But whats the point when... By rogwen ( 8 Years Ago )
Forum Post Glad you did report it because I just tried and it's a bit wonky for... By mark ( 8 Years Ago )
Forum Post [quote][b]rogwen (1/5/2018)[/b][hr]I cannot use 7.2 patch. Direct... By Rampa ( 8 Years Ago )
Forum Post The movement is not the issue.First two recordings work as expected.... By rogwen ( 8 Years Ago )
Forum Post That's what seems to be happening to me, it was by the third... By mark ( 8 Years Ago )
Forum Post Here is another issue: When adding Post Effect (Visual > Post... By TonyDPrime ( 8 Years Ago )
Forum Post Does it work if you hit delete on the keyboard? By Rockoloco666 ( 8 Years Ago )
Forum Post [quote][b]TonyDPrime (1/8/2018)[/b][hr]Here is another issue: When... By toystorylab ( 8 Years Ago )
Forum Post [quote][b]TonyDPrime (1/8/2018)[/b][hr]Here is another issue: When... By Rogue Anime ( 8 Years Ago )
Forum Post [quote][b]Rogue Anime (1/8/2018)[/b][hr] [quote][b]TonyDPrime... By TonyDPrime ( 8 Years Ago )
Forum Post Another workaround, is to simply override the key you are trying to... By 4u2ges ( 8 Years Ago )
Forum Post [quote][b]TonyDPrime (1/8/2018)[/b][hr]Here is another issue: When... By wires ( 8 Years Ago )
Forum Post [quote][b]Rampa (1/5/2018)[/b][hr][quote][b]rogwen (1/5/2018)[/b][hr]I... By TonyDPrime ( 8 Years Ago )
Forum Post Update - Direction Puppet issue can be reproduced with any avatar.... By TonyDPrime ( 8 Years Ago )
Forum Post @rogwen: It is the weekend now in Taiwan were development is situated.... By animagic ( 8 Years Ago )
Forum Post I am unable to scale Non-Human characters in iClone 7.. I can move... By WillFl ( 8 Years Ago )
Forum Post You should be able to scale your non-human character using avatar... By Clark ( 8 Years Ago )
Forum Post I seriously need my undo to work again... Being perfect all the time... By Rockoloco666 ( 8 Years Ago )
Forum Post [quote][b]raxel_67 (2/28/2018)[/b][hr]I seriously need my undo to work... By Kelleytoons ( 8 Years Ago )
Forum Post I hope this is the right place to post. When using the edit motion... By Jfrog ( 8 Years Ago )
Forum Post Yet another issue: When adding a .POPVIDEO plane that contains... By yossigolan ( 8 Years Ago )
Forum Post A note on my post above. All of the post effects can be deleted... By wires ( 8 Years Ago )
Forum Post [quote][b]wires (1/8/2018)[/b][hr]A note on my post above. All of the... By TonyDPrime ( 8 Years Ago )
Forum Post [quote][b]wires (1/8/2018)[/b][hr]All of the post effects can be... By Rogue Anime ( 8 Years Ago )
Forum Post [quote][b]Rogue Anime (1/9/2018)[/b][hr] [quote][b]wires... By 4u2ges ( 8 Years Ago )
Forum Post At minimum it would be more intuitive if you would right-click and you... By TonyDPrime ( 8 Years Ago )
Forum Post [quote][b]TonyDPrime (1/9/2018)[/b][hr]At minimum it would be more... By 4u2ges ( 8 Years Ago )
Forum Post [quote][b]4u2ges (1/9/2018)[/b][hr][quote]HDR - Yes LUT - No... By Rogue Anime ( 8 Years Ago )
Forum Post Right Val, and I found the source of the problem later on with... By 4u2ges ( 8 Years Ago )
Forum Post [quote][b]4u2ges (1/9/2018)[/b][hr]Right Val, and I found the source... By Rogue Anime ( 8 Years Ago )
Forum Post [quote][b]Rogue Anime (1/9/2018)[/b][hr] [quote][b]wires... By TonyDPrime ( 8 Years Ago )
Forum Post [quote][b]TonyDPrime (1/9/2018)[/b][hr]Ahhh...In a way, the right... By Rogue Anime ( 8 Years Ago )
Forum Post [quote][b]Rogue Anime (1/9/2018)[/b][hr] [quote][b]TonyDPrime... By TonyDPrime ( 8 Years Ago )
Forum Post Well, I just re-discovered that Speedtree still conflicts with... By TonyDPrime ( 8 Years Ago )
Forum Post [quote][b]TonyDPrime (1/13/2018)[/b][hr]MixMoves and SpeedTree... I... By Rogue Anime ( 8 Years Ago )
Forum Post Not particularly for v7.2, but there should be a better memory... By 4u2ges ( 8 Years Ago )
Forum Post Found another one. This time it's a Tessellation Shadow and it's... By 4u2ges ( 8 Years Ago )
Forum Post [quote][b]4u2ges (1/13/2018)[/b][hr]an artificial shadow (cannot even... By Rogue Anime ( 8 Years Ago )
Forum Post [quote][b]Rogue Anime (1/14/2018)[/b][hr] [quote][b]4u2ges... By 4u2ges ( 8 Years Ago )
Forum Post [quote][b]4u2ges (1/13/2018)[/b][hr]Found another one. This time it's... By mr_vidius ( 8 Years Ago )
Forum Post [quote][b]mr_vidius (1/15/2018)[/b][hr][quote][b]4u2ges... By 4u2ges ( 8 Years Ago )
Forum Post @4u2ges: Thanks for the demo project! I'll check it out, as I will be... By animagic ( 8 Years Ago )
Forum Post I have an issue with the viseme track. I load a mp3 file into the... By thedirector1974 ( 8 Years Ago )
Forum Post The slider controls how MUCH viseme track is applied -- and it works... By Kelleytoons ( 8 Years Ago )
Forum Post Really? But it was possible in previous versions of iClone! I worked... By thedirector1974 ( 8 Years Ago )
Forum Post Hi After update to 7.2 version, screen is not scaled right in 4k... By jarmoh ( 8 Years Ago )
Forum Post [quote][b]jarmoh (1/17/2018)[/b][hr] Hi After update to 7.2... By Matt GH ( 8 Years Ago )
Forum Post Just noticed, that the DOF mask is corrupted again, after updateing... By thedirector1974 ( 8 Years Ago )
Forum Post [quote][b]thedirector1974 (1/21/2018)[/b][hr]Just noticed, that the... By TonyDPrime ( 8 Years Ago )
Forum Post I already tried that - same result ... :( By thedirector1974 ( 8 Years Ago )
Forum Post Man, that sucks. I know...It's like I feel like my hands are tied... By TonyDPrime ( 8 Years Ago )
Forum Post This one is real ugly. Soft shadow is making a "parquet floor" out of... By 4u2ges ( 8 Years Ago )
Forum Post [quote][b]4u2ges (1/26/2018)[/b][hr]This one is real ugly. Soft shadow... By Rampa ( 8 Years Ago )
Forum Post Not within the reasonable values. I mean Bias value of -150 took care... By 4u2ges ( 8 Years Ago )
Forum Post I did work it around by setting "to cast shadow" only for that corner... By 4u2ges ( 8 Years Ago )
Forum Post Reducing the angle helps with this problem ... By thedirector1974 ( 8 Years Ago )
Forum Post [quote][b]thedirector1974 (1/26/2018)[/b][hr]Reducing the angle helps... By 4u2ges ( 8 Years Ago )
Forum Post been wondering if anyone else is having issues with the time line? I... By mr_vidius ( 8 Years Ago )
Forum Post Undo is not working again in 7.2 By Rockoloco666 ( 8 Years Ago )
Forum Post Can't export to custom size such as 4096x2048 . This is a very... By Jfrog ( 8 Years Ago )
Forum Post Works for me (just tried a PNG export, which is the only export anyone... By Kelleytoons ( 8 Years Ago )
Forum Post Never really played with DOF until now, and it seems kind of weak on... By TonyDPrime ( 8 Years Ago )
Forum Post The sliders are not the limit. You can put any value you want in the... By thedirector1974 ( 8 Years Ago )
Forum Post [quote][b]thedirector1974 (2/8/2018)[/b][hr]The sliders are not the... By TonyDPrime ( 8 Years Ago )
Forum Post [quote][b]TonyDPrime (2/9/2018)[/b][hr][quote][b]thedirector1974... By thedirector1974 ( 8 Years Ago )
Forum Post I am investigating an issue with Dan Genesis Hair that comes in as... By TonyDPrime ( 8 Years Ago )
Forum Post This is a follow up on my earlier post regarding overlapping textures... By TonyDPrime ( 8 Years Ago )
Forum Post [quote][b]TonyDPrime (2/9/2018)[/b][hr]This is a follow up on my... By 4u2ges ( 8 Years Ago )
Forum Post [quote][b]4u2ges (2/9/2018)[/b][hr][quote][b]TonyDPrime... By TonyDPrime ( 8 Years Ago )
Forum Post I was not really sure if that would work, because you had monstrous... By 4u2ges ( 8 Years Ago )
Forum Post Playing around some more with the artifacting hair due to overlapping... By TonyDPrime ( 8 Years Ago )
Forum Post [quote][b]TonyDPrime (2/8/2018)[/b][hr]Never really played with DOF... By TonyDPrime ( 8 Years Ago )
Forum Post [quote][b]TonyDPrime (2/13/2018)[/b][hr][quote][b]TonyDPrime... By Rampa ( 8 Years Ago )
Forum Post [quote][b]raxel_67 (2/7/2018)[/b][hr]Undo is not working again in... By justaviking ( 8 Years Ago )
Forum Post i[quote][b]justaviking (2/9/2018)[/b][hr][quote][b]raxel_67... By Rockoloco666 ( 8 Years Ago )
Forum Post [quote][b]raxel_67 (2/15/2018)[/b][hr] nope, i can create a new scene... By wires ( 8 Years Ago )
Forum Post [quote][b]wires (2/15/2018)[/b][hr][quote][b]raxel_67... By Rockoloco666 ( 8 Years Ago )
Forum Post Yeah, I definetly enountered broken undo, but not consistently. I only... By justaviking ( 8 Years Ago )
Forum Post [quote]Works for me (just tried a PNG export, which is the only export... By Jfrog ( 8 Years Ago )
Forum Post If I open a window to import an asset, open a project, save a project,... By inash ( 8 Years Ago )
Forum Post [quote][b]ilyas.hosea (2/20/2018)[/b][hr]If I open a window to import... By GOETZIWOOD STUDIOS ( 8 Years Ago )
Forum Post [quote][b]ilyas.hosea (2/20/2018)[/b][hr]If I open a window to import... By WillFl ( 8 Years Ago )
Forum Post When I have a character selected and then click on the Edit Reach... By jenjon ( 8 Years Ago )
Forum Post Discovered some info on the Daz Hair Opacity Front. So, in iC7 we... By TonyDPrime ( 8 Years Ago )
Forum Post I assume you filed a bug report on this -- update your findings in... By Kelleytoons ( 8 Years Ago )
Forum Post [quote][b]Kelleytoons (3/16/2018)[/b][hr]I assume you filed a bug... By TonyDPrime ( 8 Years Ago )
Forum Post well now.. this is what happens. when you want iclone to do everything... By mr_vidius ( 8 Years Ago )
Forum Post [quote][b]mr_vidius (3/17/2018)[/b][hr]well now.. this is what... By TonyDPrime ( 8 Years Ago )
Forum Post Is anyone else having problems with Substance PBR 200 materials? They... By CtrlZ ( 8 Years Ago )
Forum Post What are your display settings? Do you have them on High or something... By Kelleytoons ( 8 Years Ago )
Forum Post [quote][b]Kelleytoons (3/20/2018)[/b][hr]What are your display... By CtrlZ ( 8 Years Ago )
Forum Post 7.21 around the corner- Hoping for these bug fixes: 1) Opacity... By TonyDPrime ( 8 Years Ago )
Forum Post I have just got the hang of the new concept of linking versus... By elliespotter ( 8 Years Ago )
Forum Post I don't think that link symbol really means anything when it comes to... By Kelleytoons ( 8 Years Ago )
