Questions & Issues
Posted By jlittle 10 Years Ago
lesdodds
lesdodds
Posted 10 Years Ago
Distinguished Member (2.8K reputation)Distinguished Member (2.8K reputation)Distinguished Member (2.8K reputation)Distinguished Member (2.8K reputation)Distinguished Member (2.8K reputation)Distinguished Member (2.8K reputation)Distinguished Member (2.8K reputation)Distinguished Member (2.8K reputation)Distinguished Member (2.8K reputation)
Posts: 246, Visits: 2.6K
jlittle (11/4/2016)
Whoops, ran it a second time and I get what you got.
I guess the Beta test has ended.
Jeff
Start it offline if you need to finish something, it works.
Lester:)
 My YouTube
My Facebook
"All the adversity I've had in my life, all my troubles and obstacles, have strengthened me... You may not realize it when it happens, but a kick in the teeth may be the best thing in the world for you."
-Walt Disney
jlittle
jlittle
Posted 10 Years Ago
Posts: 1.9K, Visits: 17.3K
Jeff
jlittle
jlittle
Posted 10 Years Ago
Just tried mine and no problem here.
Jeff
VES
VES
Posted 10 Years Ago
Posts: 55, Visits: 639
After using CTA 3 beta today, when I restarted it, I was notified my serial number was invalid.  Did this test expire?  Or is there another problem?  Anyone else have this happen?
jlittle
jlittle
Posted 10 Years Ago
Nice!
Jeff
brothertcoleman
brothertcoleman
Posted 10 Years Ago
Posts: 578, Visits: 6.1K
Cool
In CTA2 I had a complete silhouette band playing in the background as I had a singer  in the foreground singing but using CTA3 will be so much better.
This is a rough draft using CTA3 but key framing took a little time ,would be nice to have direct puppet and Bone Tools /Break available.
jlittle
jlittle
Posted 10 Years Ago
Hope you don't mind but your silhouette inspired this little clip.
Once I found the right music I just did a short piece playing around with it .
Jeff
brothertcoleman
brothertcoleman
Posted 10 Years Ago
Thanks Jeff ,appreciate your help.
jlittle
jlittle
Posted 10 Years Ago
I would do it like this:
You get good movement using just a couple of the bones:
Jeff
jlittle
jlittle
Posted 10 Years Ago
Your are trying to connect the wrong ends of the bones together.
Each bone has a Root end and a Stub (pointy) end.
You can only connect the Stub to a Root.
You are trying to connect the two Stubs together which you can't do.
Jeff
EDIT: Removed what I though was a solution.
Evidently you can't connect bones in a circle.
