lesdodds
lesdodds
Visits: 2.6K
jlittle (11/4/2016) Whoops, ran it a second time and I get what you got. I guess the Beta test has ended.
Jeff
Start it offline if you need to finish something, it works.
 Lester:) My YouTube My Facebook "All the adversity I've had in my life, all my troubles and obstacles, have strengthened me... You may not realize it when it happens, but a kick in the teeth may be the best thing in the world for you." -Walt Disney
jlittle
jlittle
Posts: 1.9K,
Visits: 17.3K
Whoops, ran it a second time and I get what you got. I guess the Beta test has ended. Jeff
jlittle
jlittle
Posts: 1.9K,
Visits: 17.3K
Just tried mine and no problem here. Jeff
VES
Visits: 639
After using CTA 3 beta today, when I restarted it, I was notified my serial number was invalid. Did this test expire? Or is there another problem? Anyone else have this happen?
jlittle
jlittle
Posts: 1.9K,
Visits: 17.3K
Nice! Jeff
brothertcoleman
brothertcoleman
Last Active: 7 hours ago
Visits: 6.1K
Cool In CTA2 I had a complete silhouette band playing in the background as I had a singer in the foreground singing but using CTA3 will be so much better. This is a rough draft using CTA3 but key framing took a little time ,would be nice to have direct puppet and Bone Tools /Break available.
jlittle
jlittle
Posts: 1.9K,
Visits: 17.3K
Hope you don't mind but your silhouette inspired this little clip. Once I found the right music I just did a short piece playing around with it . Jeff
brothertcoleman
brothertcoleman
Visits: 6.1K
Thanks Jeff ,appreciate your help.
jlittle
jlittle
Posts: 1.9K,
Visits: 17.3K
I would do it like this:  You get good movement using just a couple of the bones:
Jeff
jlittle
jlittle
Posts: 1.9K,
Visits: 17.3K
Your are trying to connect the wrong ends of the bones together. Each bone has a Root end and a Stub (pointy) end. You can only connect the Stub to a Root. You are trying to connect the two Stubs together which you can't do. Jeff EDIT: Removed what I though was a solution. Evidently you can't connect bones in a circle.
