ninichan
ninichan
Posted 10 Years Ago
Last Active: 9 Years Ago
Visits: 16
I try to open Edit motion layer button with another character, this time the system didn't crush, but the display box appear with no text.
Ola(RL)
Ola(RL)
Posted 10 Years Ago
Last Active: 6 Years Ago
Visits: 2.4K
This is probably because the program is run on Mac parallel environment. We are addressing this problem now.
brothertcoleman
brothertcoleman
Posted 10 Years Ago
Visits: 6.1K
Not sure if I'm doing something wrong or its an issue with connecting bones.
jlittle
jlittle
Posted 10 Years Ago
Posts: 1.9K,
Visits: 17.3K
Your are trying to connect the wrong ends of the bones together. Each bone has a Root end and a Stub (pointy) end. You can only connect the Stub to a Root. You are trying to connect the two Stubs together which you can't do. Jeff EDIT: Removed what I though was a solution. Evidently you can't connect bones in a circle.
jlittle
jlittle
Posted 10 Years Ago
Posts: 1.9K,
Visits: 17.3K
I would do it like this:  You get good movement using just a couple of the bones:
Jeff
brothertcoleman
brothertcoleman
Posted 10 Years Ago
Visits: 6.1K
Thanks Jeff ,appreciate your help.
jlittle
jlittle
Posted 10 Years Ago
Posts: 1.9K,
Visits: 17.3K
Hope you don't mind but your silhouette inspired this little clip. Once I found the right music I just did a short piece playing around with it . Jeff
brothertcoleman
brothertcoleman
Posted 10 Years Ago
Visits: 6.1K
Cool In CTA2 I had a complete silhouette band playing in the background as I had a singer in the foreground singing but using CTA3 will be so much better. This is a rough draft using CTA3 but key framing took a little time ,would be nice to have direct puppet and Bone Tools /Break available.
jlittle
jlittle
Posted 10 Years Ago
Posts: 1.9K,
Visits: 17.3K
Nice! Jeff
VES
Visits: 639
After using CTA 3 beta today, when I restarted it, I was notified my serial number was invalid. Did this test expire? Or is there another problem? Anyone else have this happen?
