You can just in your case, if I understand correctly what you are looking to do,
just paint the character Black and use them as a shadow....
http://www.youtube.com/watch?v=QTrNGf6Ak0gIn this Clip you will see "Jana" during a morning workout, "Shadow Boxing".
1. She was first turned completely Black(Skin, Hair, Clothing, Etc.), then Exported as a Widget.
2. Re-imported as a Widget and placed on a Flat Plane, then Flipped 180 deg. and placed against the wall.
The Original Characters Clothing and Skin was returned to Normal so she could "Shadow Box" with the light from behind her casting a shadow of her on the wall...(Not really of course).
The Lamp sitting behind her is there to perpetuate the lie that she is in fact "Shadow Boxing" It has a Glowing Ball placed on the front to simulate it is on.
Without putting the character on a Flat Plane as a Widget it would not have given you the Reversed and Mirrored image. Just reversing the motion will not do. You have to apply it, then flip it.
Oh yeah, the motion you export as a widget must match exactly as the character and be timed the same "Frames Per Second" when creating the Widget.
This has been a short "Widget" learning experience...try and see if you can do it. It's easier than it looks.
P.S. Substitute the word popVideo for WIDGET as the widget was the only thing available when it was produced, but the same principle applies to using a popVideo on a Flat Plane
SKYPE ID: rc.650
