Load time is slow with widget cast "why"
Posted By darryl.townsend 15 Years Ago
darryl.townsend
darryl.townsend
Posted 15 Years Ago
Senior Member (299 reputation)Senior Member (299 reputation)Senior Member (299 reputation)Senior Member (299 reputation)Senior Member (299 reputation)Senior Member (299 reputation)Senior Member (299 reputation)Senior Member (299 reputation)Senior Member (299 reputation)
Last Active: 15 Years Ago
Posts: 1, Visits: 19
Hello I am using widgetcast pro to create video spokespersons. After I create them using pop video converter then widgetcast I use the self-host option. I load my files to my server and place my html code where I want the video to play. Comparing this product with other similar sites my video load times are almost twice then theirs. It's taking my videos almost 10 seconds to load compared to a 3-4 second load times with competitors. By the way my videos are less then 30 seconds. Can someone please give me some advice.....
safegaard
safegaard
Posted 15 Years Ago
Veteran Member (862 reputation)Veteran Member (862 reputation)Veteran Member (862 reputation)Veteran Member (862 reputation)Veteran Member (862 reputation)Veteran Member (862 reputation)Veteran Member (862 reputation)Veteran Member (862 reputation)Veteran Member (862 reputation)
Posts: 360, Visits: 984
The first thing that come in to my mind is that you maybe have made your videos in a high or memory taking file format.
When you do your videos you can do them in any format you like but when you convert them at last it should be in an format that of course is as high resolution that you need but same time in a video format that only fill so low in mb as possibly.
You should experiment to make the file´s in format thats low in mb but still in good quality.
Its like making websites, one need to have pictures and movies that look great but it has to be converted to format an resolutions that is so low in mb as possible or it takes forever to load.
When you use Widgetcast you need to think off how many mb all the stuff you put in has so you can go so low in output mb as possible.
I dont know if this help you but try experimenting, and good luck. :)
For the love of 3d http://www.safegaard.com
Posted 15 Years Ago
darryl.townsend (3/29/2011)
If you are still having problems please contact Reallusion Technical Support using the link below. They will be able to advise you on the problems you are having and the best way to resolve them.
Thanks.
