So I have a character, I brought in a prop, an image, saved it as a prop. Then opened the character in Character composer, brought in the prop; scaled, rotated, positioned it as I wanted it then when I moved back out onto the stage the prop placement was totally screwed up. Waaaay off the mark...
So Reallusion, what is the secret to prop placement? In the attached screen shots, see it in the character composer, then see it on the stage. One of the props (the one on screen right) is behind the character, and when I try to bring it forwards in the z-depth I have to keep scaling it down so it's correct, and eventually it just disappears altogether. IfI go into the 3D view, I can't even find it...
