shavonne.w
shavonne.w
Posted 2 Years Ago
Visits: 110
same issue, none of the proposed solutions work.
ChengJhong(RL)
ChengJhong(RL)
Posted 2 Years Ago
Visits: 36
If zplugin exist, please check if you have any zbursh that has been removed but still in registry. Currently, the registry of zbrush that doesn't exist have to removed manually. It should be under HKEY_LOCAL_MACHINE\SOFTWARE\Maxon\
ChengJhong(RL)
ChengJhong(RL)
Posted 2 Years Ago
Visits: 36
Please check if folder CCGoZData and file CCGoZ.zsc are under C:\Program Files\Maxon ZBrush 2024\ZStartup\ZPlugs64 (Default zbrush 2024 install path). If not, please copy from <path to chraracter creator>\Character Creator 4\Resource\ICGoZBrush\ZBScript to ZPlugs64. CC GoZ Plus will be under Zplugin.
 ChengJhong Reallusion
shavonne.w
shavonne.w
Posted 2 Years Ago
Visits: 110
Similar issue, unable to finish my round trip from Zbrush back to CC. Given how much CC costs, the speed of responses from them on this sort of issues is honestly way too slow..
Posted 2 Years Ago
Posts: 23.1K,
Visits: 36.6K
If you are still having problems, please contact Support using the link below. They will help you with this issue. https://www.reallusion.com/CustomerSupport/UserEx/QForm.html
dramzii23
dramzii23
Posted 2 Years Ago
Visits: 2
x 2.
Facing the same issue.
massimorossa
massimorossa
Posted 2 Years Ago
Visits: 6
I've the same problem. Did you find a solution?
bluesexperience1969
bluesexperience1969
Posted 2 Years Ago
Visits: 2
I installed the latest version of zbrush(2024.0.4) and character creator(v4.42),then i followed the guide and install the zbrush pose tools and zbrush pose link(v1.01). When i opened zbrush and goz a mesh into CC, it warns me that i'm not using "CC GOZ Plus" plugin so the diffuse map and normal map will not be updated, but the mesh did went into CC, but when i tried to goz it back to zbrush, a series of warning pops up. At first it tells me to close zbrush so it will automatically install the CC GOZ Plus plugin, Then it says the diffuse map and normal map can't be located, finally the whole processe failed due to "data processing in zbrush", i'm supposed to waite or click the "restart CC GOZ plus" button in the zbrush CC GOZ plus plugin which i didn't find in zbrush plugin menu. I tried a several times, this one time zbrush also pops up an error, i don't know what it means but it seems like it's related to the CC GOZ plus plugin.So please informe me which step i went wrong?
