Live Face - Recording in 60 fps - Duplicate frames
Posted By Utte 2 Years Ago
Utte
Utte
Posted 2 Years Ago
Junior Member (109 reputation)Junior Member (109 reputation)Junior Member (109 reputation)Junior Member (109 reputation)Junior Member (109 reputation)Junior Member (109 reputation)Junior Member (109 reputation)Junior Member (109 reputation)Junior Member (109 reputation)
Posts: 3, Visits: 146
I'm recording face capture using Live Face in Iclone. The issue is that when I record it with the project set to 60 fps it creates a bunch of duplicate frames that are exactly the same for every blendshape. Most of the time it's just two frames after each other that are the same, but sometimes it's up to 3-5 in a row.
My first thought was that the camera I'm using was limited to 30 fps, but that is not the case. I'm using an Iphone 13 pro, so the front camera is recording in 60 fps. Not every other frame is a duplicate in the recordings either, so that doesn't make sense. When I set the project to 30 fps I do not get any duplicate frames - or they are very rare.
What I'm considering now is either if it's a limitation in the software or if the Iphone simply can't send that amount of data to the computer via wifi in realtime. Do you think buying an ethernet cable adapter for the phone might resolve this issue? Or do you have any other suggestions I could try?
I've tried to solve this issue for days now, and I just can't figure out how. Hopefully you can help me with this!
Thank you!
https://forum.reallusion.com/uploads/images/486277fa-e1fa-478c-9f51-50d1.png
