Transfer Visemes in Unity in form of Blendshapes
Posted By hahadzagic 3 Years Ago
hahadzagic
hahadzagic
Junior Member (103 reputation)Junior Member (103 reputation)Junior Member (103 reputation)Junior Member (103 reputation)Junior Member (103 reputation)Junior Member (103 reputation)Junior Member (103 reputation)Junior Member (103 reputation)Junior Member (103 reputation)
Posts: 1, Visits: 178
I need an advice what would be the best way to transfer visemes into Blend Shapes in Unity for the purpose of automated speech?
Any advice is very helpful and appreciated.
Thank you
dan.goyette
dan.goyette
Veteran Member (825 reputation)Veteran Member (825 reputation)Veteran Member (825 reputation)Veteran Member (825 reputation)Veteran Member (825 reputation)Veteran Member (825 reputation)Veteran Member (825 reputation)Veteran Member (825 reputation)Veteran Member (825 reputation)
Posts: 83, Visits: 379
This is all pretty much automatic as long as you add the appropriate Expressions to the model, and use the AutoSetup tool to import the model in Unity. The default character should have a bunch of expression blend shapes that can be used.
There are also a bunch of ARKit visemes you can also add. Find the CC3+ Traditional Facial Profile and add it. Then, choose just to Add instead of Replace, and just the Custom Expressions.
What lip sync tool are you using in Unity?
Last Active: 10 days ago
Depending if you need the Reallusion standard visemes, or the more traditional for games 15 visemes, you can switch between the viseme sets. See here:
https://manual.reallusion.com/Character-Creator-4/Content/ENU/4.0/06-Facial-Profile-Editor/8_7_and_1_1.htm
