bob.weber
bob.weber
Visits: 28
Hi there, I am new to CTA, so hopefully this is easy to fix: I have imported a prop from an SVG file (created in Illustrator), it looks perfectly fine within CTA viewport. But when rendering it gets heavily aliased (jagged edges, see image on the left). For testing I have imported the same prop as PNG, this always looks fine, both in the viewport and in the rendering. I have also tried to activate Super Sampling. It gets better, but not as smooth as with the PNG. I thought using vectors would always be the better choice for image quality. Am I missing something?  Thanks, Bob
Famekrafts
Famekrafts
Visits: 2.0K
I have rendered - the robot as a vector image and it is not jagged at all. Maybe when creating in illustrator, try to enlarge the vector image to a big HD size, you can always resize it in CTA5. Even as PNG files, always use HD-size images, which can be scaled down. animation
CTA5, Iclone 7, 3D Exchange Pro, Character Creator 3, Popcornfx plugin, Zbrush, Blender, Vue 2014, Adobe cc suite, Spriter Homebuild Workstation (Pretty old now but still working great) Win 10, Intel i7 950, 24 GB RAM DDR3, Gigabyte x58a-ud7 motherboard, AMD R9 390 sapphire 8GB VRAM. Official Website Reallusion Store
Edward (RL)
Edward (RL)
Last Active: Yesterday
Visits: 4.9K
bob.weber (1/5/2023) Hi there, I am new to CTA, so hopefully this is easy to fix: I have imported a prop from an SVG file (created in Illustrator), it looks perfectly fine within CTA viewport. But when rendering it gets heavily aliased (jagged edges, see image on the left). For testing I have imported the same prop as PNG, this always looks fine, both in the viewport and in the rendering. I have also tried to activate Super Sampling. It gets better, but not as smooth as with the PNG. I thought using vectors would always be the better choice for image quality. Am I missing something? Thanks, Bob
Hello,
Thanks for the issue reporting. Please submit a support ticket; we may need some data from you. :laugh:
Edward
bob.weber
bob.weber
Visits: 28
Thanks for the tip Famekrafts, but it is already created with an artboard and export width of 2K, so that should not be the problem. I have just created a support ticket with the SVG file attached, maybe you will find something.
Thanks, Bob
