What standard the RVisemeKey enum based on?
Posted By ifarkas 4 Years Ago
ifarkas
ifarkas
Senior Member (405 reputation)Senior Member (405 reputation)Senior Member (405 reputation)Senior Member (405 reputation)Senior Member (405 reputation)Senior Member (405 reputation)Senior Member (405 reputation)Senior Member (405 reputation)Senior Member (405 reputation)
Last Active: 3 Months Ago
Posts: 18, Visits: 59
Hi Dev Support,What's the Phoneme/Viseme mapping to IPA, X-SAMPA, ARPABET standards, please?My goal is to map AWS Polly visemes to RVisemeKey enum.
Thx, IvanRLPy.EVisemeID_NONERLPy.EVisemeID_EERLPy.EVisemeID_ERRLPy.EVisemeID_IHRLPy.EVisemeID_AHRLPy.EVisemeID_OHRLPy.EVisemeID_W_OORLPy.EVisemeID_S_ZRLPy.EVisemeID_CH_JRLPy.EVisemeID_F_VRLPy.EVisemeID_THRLPy.EVisemeID_T_L_D_NRLPy.EVisemeID_B_M_PRLPy.EVisemeID_K_G_H_NGRLPy.EVisemeID_AERLPy.EVisemeID_R
Johnny (RL)
Johnny (RL)
Junior Member (180 reputation)Junior Member (180 reputation)Junior Member (180 reputation)Junior Member (180 reputation)Junior Member (180 reputation)Junior Member (180 reputation)Junior Member (180 reputation)Junior Member (180 reputation)Junior Member (180 reputation)
Posts: 17, Visits: 646
ifarkas (9/6/2022)
Hi ifarkas,
You should do the mapping yourself. Aws Polly has its own viseme, which you can map to the RL's viseme
You may need to adjust this mapping table back and forth to achieve the best Lipsync result.
Similar to the following code:
        awspolly_mapping_dict = {
            "p"  : RLPy.EVisemeID_B_M_P,
            "t"  :  RLPy.EVisemeID_T_L_D_N,
            "S"  : RLPy.EVisemeID_S_Z,
            "T"  : RLPy.EVisemeID_T_L_D_N,
            "a"  : RLPy.EVisemeID_AH,
            "o"  : RLPy.EVisemeID_W_OO,
            # .....more
        key_list = []
        time_list = []
        weight_list = []
        for i in range(len(AWSPollyData)):
            key = int(awspolly_mapping_dict[AWSPollyData[I].viseme])
            time =AWSPollyData[I].time
            key_list.append(key)
            time_list.append(time)
            weight_list.append(100)
        result = viseme_component.AddVisemesClipWithData(_set_time, _name, _audio_object, time_list, key_list, weight_list)
ifarkas
ifarkas
It was painful, but I did it. I had to map to the map. Thx.
