AccuLips audio file shortening issue
Posted By section_33 3 Years Ago
Jeffster The Mighty
Jeffster The Mighty
Distinguished Member (3.2K reputation)Distinguished Member (3.2K reputation)Distinguished Member (3.2K reputation)Distinguished Member (3.2K reputation)Distinguished Member (3.2K reputation)Distinguished Member (3.2K reputation)Distinguished Member (3.2K reputation)Distinguished Member (3.2K reputation)Distinguished Member (3.2K reputation)
Posts: 308, Visits: 1.2K
I've never had this problem. Of course, if this problem continues for you,  the obvious fix is to tack on as much silence as needed to the end of your audio files.
What are the specifications of your audio file? 16-bit @ 44.1 or 48 kHz should give you no problem. I usually use WAV format, but MP3 should work too.
section_33
section_33
Junior Member (158 reputation)Junior Member (158 reputation)Junior Member (158 reputation)Junior Member (158 reputation)Junior Member (158 reputation)Junior Member (158 reputation)Junior Member (158 reputation)Junior Member (158 reputation)Junior Member (158 reputation)
Posts: 7, Visits: 74
Scene length is maxed out to 5 mins but the audio clips are only 10-15 seconds at a time. So That's not the cause here
Posts: 5.7K, Visits: 26.5K
Thai normally only happens when the scene length set in iClone is shorter than the audio being imported.
section_33
section_33
SO I'm trying to do some animations on a shot shot basis for a live action/animation mix project and noticed that the audio brought in (from a 23.976fps video project) Acculips is trimming off the end on import so it's never bringing in the full audio file.
Any suggestions for getting the audio into Acculips/iClone without it losing material
