iClone crash on callback
Posted By professor_wm 5 Years Ago
professor_wm
professor_wm
New Member (69 reputation)New Member (69 reputation)New Member (69 reputation)New Member (69 reputation)New Member (69 reputation)New Member (69 reputation)New Member (69 reputation)New Member (69 reputation)New Member (69 reputation)
Posts: 3, Visits: 25
starting with python API I think I have to learn a lot. However at once I get iClone to crash. I try to implement some MIDI data reading (for different issues). So I define a MIDI callback function and open the MIDI device. So far so good. Also I know that the callback receives some data, but whenever I try to call any iClone API function it crashes immediately. I assume that the callback is in a different threat and that therefore I get the crash. So the next attempt is to use a callback to a window but I cannot get the hwnd window handle. I know that Qt supports this (xyz.winId()) but I have no idea how this works with the iClone API.
Anyone any idea to one of these problems?
many thanks
Tesira
Tesira
Posts: 1.3K, Visits: 2.4K
hi professor_wm,
have a look at this demo. It dos not crash my computer and gives the mainwindow.
main_window_address = RLPy.RUi.GetMainWindow()
https://wiki.reallusion.com/IC_Python_API:Screenshotting#User_Interface
Tesira
professor_wm
professor_wm
Hi Tesira,
many thanks for your answer. However according to description this function returns => "
Get the QWidget address for the main window." Which is not the window handle (hwnd). So this is not working.
Tesira
Tesira
Well the script dos show the screenshoot of the mainwindow. So it should know the mainwindow. Or look here.
main_rl_dlg.SetParent(RLPy.RUi.GetMainWindow())
https://wiki.reallusion.com/IC_Python_API:RLPy_RIDialog
But I also have problems with crashes of the event handler and the dialog event handler.
So good luck for you.
Tesira
professor_wm
professor_wm
"RLPy.RUi.GetMainWindow()" does not return the window handle. It returns the lets say Qt window handler or object. So this does not work.
However I found out that xyz.winId() is working and returns the HWND. So the code would be:
mainWindow = wrapInstance(int(RLPy.RUi.GetMainWindow()), QtWidgets.QMainWindow)
mainWindowHWND = mainwindow.winId()
The simple truth is in my code I wrote it wrong ".WinId()" instead of ".winId()" and did not notice it even when checking it.
OMG what a binners mistake I could not believe it when I saw it.
Many thanks again for your answers.
Tesira
Tesira
Great to hear. Thanks to you. So I have also learned a few things.
Tesira
