included ? / if not some basic improvements
Posted By JaimesBond 16 Years Ago
JaimesBond
JaimesBond
Posted 16 Years Ago
Veteran Member (504 reputation)Veteran Member (504 reputation)Veteran Member (504 reputation)Veteran Member (504 reputation)Veteran Member (504 reputation)Veteran Member (504 reputation)Veteran Member (504 reputation)Veteran Member (504 reputation)Veteran Member (504 reputation)
Last Active: 10 Years Ago
Posts: 10, Visits: 15
import:
keep the points = reimporting the Model-picture without to set the points again (f.e. i have same motives in the pic in diff. colours, with diff. backgrounds/logos in the pic)
output:
set samplerate/encoder/kbps of the audio
in general:
more than 4 objects to animate
number of marker points:
possibility to set as many points as you want (f.e. if u have a mouth with many/different edges or some salient/over the lips viewable teeth the actual 8 ? are much to less)
save exportsettings (video encoder, videoformat, ...) with the project
its annoying to set each time the same settings again and again
possibility to use heads/faces that are not centered (f.e. eyes not on the same horizontal line) , cause at the moment the head animations don´t work properly for those.
btw.:
1. the official contactform is not https, so you should not ask to send the full serial.
2. by using the internal updatecheck the website wrongly say last Version : 6.12.0923" but last version is 6.13.xx
Posted 16 Years Ago
Many thanks for the feedback. They will be passed to the development team for review. :)
