DISCLAIMER: This enhancement is not provided by the author of this program and is a "third party" enhancement.
These files will not run on their own and require ownership and installation of the Nature Terrain Generator Plugin.To revert back to the original Plugin just re-run the downloaded NatureTerrianGenerator.exe file that originally installed the plugin.Enhancements: Fixed window docking You can now dock the NTG window
Added descriptions to the texture list The list of textures now include a description.
Note: There is a new config.json file with the descriptions that replaces the existing one.
Descriptions can be changed using the new "Texture" tab (see next enhancement below).
Added new tab "Textures" A new tab was added to edit the descriptions of existing textures and to add or delete textures.
Added new morph "Edge Curl" A new morhp "Edge Curl" was added to help blend the edges of differing terrains.
The edge curl can be moved up or down.
Here is a quick demo blending differing planes together using the Mixer and Edge Curl:
If there are any issue or you think of other possible enhancements please let me know.
Jeff
Get my Plugin Manager and TaskNotes plugins for iClone.
Check out EZColors and Other products for CTA/CA. EZColors: the easy way to change Render Styled (RS) colors!
