Tugpsx
Tugpsx
Last Active: 3 Months Ago
Visits: 414
Here is info on wheel rotation.
woody173
woody173
Visits: 571
Hi guys scived off work for a bit to see if these suggestions worked and VOILA it did!!!!!. Thank you so much . I now have a vehicle with physics.....my first attempt too. I am hoping this will become a regular occurance. Just to mention it wasnt completely my fault. The video tutorial from iclone i watched on youtube did fail to mention the body dummy should be top of the heirachy https://drive.google.com/file/d/1k965Zi3Wbe6axgR-z3JjtM8JFtkkY4o0/view?usp=sharingMany thanks again
woody173
woody173
Visits: 571
I got rid of all the physics in the end and was going to just rotate the wheels manually but i dont really like the result as the animation seems to stop and start after the first 100mframes. Im still looking into it so ill get back to you all once i try it again. Also once i have the physics working how can I stop them rotating when the vehicle stops. Their is no constraint keyframe on the timeline. But as I say i dont give up easily so ill let you know what the outcome is once ive reworked the problem. Thanks guys really appreciate the help
woody173
woody173
Visits: 571
Last Active: 5 Months Ago
Visits: 31.4K
woody, could you show what it looks like in the Scene Manager? As you can see from Gerry's screenshot, the top level is the Physics dummy with everything else attached to that, both the body mesh and the wheels.
Last Active: 4 days ago
Posts: 5.7K,
Visits: 26.5K
If everything is attached and you have the prop selected in the Scene then just switch to the Props section in the Content tab, press the + at the bottom right and the prop will be added to your Custom props folder where you can name it to whatever you need.
woody173
woody173
Visits: 571
Sorry the translation is not very good. Do you want to buy it, because i was only using it for my own project. Im not sure if i can sell it but I would gladly give it to you for free if it is of any help. We all need to help each other if we can.
Thats my motto
woody173
woody173
Visits: 571
Yeh everything is attached but no joy im assuming it needs to be saved as an iprop but i dont know how to do that Thanks
matenn30
matenn30
Visits: 3.3K
I'm looking forward to the carriage. When selling If it is cheaper than the price, you may purchase it according to your own policy on the 26th. I'm looking forward to maket place. 馬車は楽しみです。販売する場合値段により安ければ26日自分のポリシーで購入する場合があります。maket place楽しみです。 This comment is bilingual in Japanese and English. このコメントは日英2か国語です。
The forum is an amateur. フォーラムは素人です。
Posts: 5.7K,
Visits: 26.5K
Open the Scene Manager tap and make sure that your prop is selected:  Click on the arrow to the left of the prop name to expand the parts list:  Everything that is attached to the main/base prop should be visible in the list. If anything is not included in the list, but is shown separate in the Scene Manager then it isn't attached
