Vladski
Vladski
Visits: 450
For the clothes, the boots I used are from the Character Creator collection models. All the other parts of clothing are made by me in Marvelous Designer and Substance Painter for the texturing. The workflow was pretty standard Marvelous to Substance Painter. I have uploaded the final version on the contest page and on Artstation. You can find it here if you want to have a look at more renders: https://www.artstation.com/artwork/xJv852?fbclid=IwAR2Fz56sJQYAmzgMkKR3cbdAYZymf94jar602_2MvtMTFQxMeV8uB9Lelnc
Vladski
Vladski
Visits: 450
Two previews on how the model and shaders work in Eevee viewport.
Vladski
Vladski
Visits: 450
With all the pieces of the puzzle in place, I could move to lightning and shading the model for the final result. Here, I played a bit with Octane and Cycles but the render times compared to Eevee are, well, unreasonable for 2020. I also tried exporting everything to Unreal Engine too but I encountered problems with the hair alembic. It made Unreal crash or I was having weird scale/interpolation issues with it and I didn't manage to find a fix for it. Maybe final 4.26 will fix these problems or I will be less dumb in the future, hope for the best! :D The shaders in Eevee are a bit of a node mess, I will share them when I have time to clean them up. The most important tip I can share for now(if you like tips) is to play with coloramps on the textures for roughness and transmission and that will give you better control on the sss and reflections. That's what worked for me, at least. For the animation, I used morphs/shape keys to fix intersection problems with the body and I also masked most of the body as you can see.
Vladski
Vladski
Visits: 450
Next step was to take everything into Blender and make the hair. The process was pretty straight forward; I've painted weightmaps for the 5 regions of the head that will have hair, like you see in the attached screenshot. It was a matter of tweaking and brushing untill I got something that looked close to the reference. One thing that I've notice lately is that sometimes it is better to use simple interpolation for the hair children instead of the interpolated one, especially for clumping; it looks better if simple interpolation is used.
Vladski
Vladski
Visits: 450
Having the model and the animation ready it was time to jump to another part of my adventure and that is Houdini to try the new Kinefx tools that are especially made to tweak mocapped animations. I noticed in the step before that the shoulders of the character were a bit inwards in different poses and since I'm a sucker for making simple things harder, I chose not to do that in Iclone and adjust it manually but to take the automation route to see how that works and learn something new in the process. Took a bit but in the end I got it working and the tool automatically adjusts the angle of the shoulders based on the pose of the character. Pretty neat! Maybe there is such a thing in Iclone as well and I don't know about it?
Vladski
Vladski
Visits: 450
Happy with the model but also constrained by time if I wanted to finish the animation in time, I moved to Iclone. Click, export, magic, model is ready for animation in Iclone. I had in mind what I wanted to animate already, it was a speech that Grindelwald holds in Lestrange Mausoleum. I prepared the sound clip from that part and imported it into Iclone; next, I took a walking and talking animation, dragged and dropped it on the character and taadaa, I had a moving Grindewald. Next, I set upt the cameras and the cuts; it is super sweeeet that Iclone manages to keep the high frame rate while animating, the process was smooth as butter. With the camera set up, character moving and the speech in the file, it was time to adjust the body motion to make it a bit better and to do the lipsynch. Using the body puppet, face puppet and edit motion layer I was able to get the whole thing to a decent level in around 4-5 hours of work overall. And again, having 60 fps in the viewport (with clothes off as you can see), makes the process quite playful; it's nice not fighting with the software when you try to achieve something.
Vladski
Vladski
Visits: 450
Vladski
Vladski
Visits: 450
Having the clothes in, I continued playing with the morph sliders and skingen textures to try to get a better match of Johnny Depp's Grindelwald. Again, the process is fun as it does not have to be linear and I can change the model, textures and props and have them all rigged instantly. When I was happy with the look of the face I started testing it with different expressions and adjust the proportions and textures while using references with the same expression.
Vladski
Vladski
Visits: 450
Vladski
Vladski
Visits: 450
