Arrows to move object do not display
Posted By ABCstudybackup 6 Years Ago
ABCstudybackup
ABCstudybackup
New Member (71 reputation)New Member (71 reputation)New Member (71 reputation)New Member (71 reputation)New Member (71 reputation)New Member (71 reputation)New Member (71 reputation)New Member (71 reputation)New Member (71 reputation)
Posts: 2, Visits: 14
When I select an object it does not show the three arrows which makes it hard to scale and rotate. How can I display these?
Thanks in advance!
Robin
Hi Robin... If you are using iClone you can press CTRL+Q to toggle on and off the Transform Gizmo.
ABCstudybackup
ABCstudybackup
That's not working...
Do make sure you the object selected (it will have a yellow bounding box around it) and hit the W, E, R keys on your keyboard to switch between Move, Rotate and Scale (Scale not available for characters).
It's also worth zooming out a little as the Gizmo may appear outside your view if you are zoomed in. For example, it will appear at a characters feet so you will not see it if you are zoomed in on the face.
Do also try loading a different character or prop like a 3D Block to check if the issue is only with that one object.
If you do still have problems, please post a full screenshot showing iClone open with the problem character/prop loaded.
