The following problem occurred...The following problem occurred...
Threaded View
Threaded View
Forum Post How to detach an attached prop? By tallon ( 7 Years Ago )
Forum Post You have to make it invisible once it is on the ground and replace it... By vepop ( 7 Years Ago )
Forum Post For this case, use " LINK " rather than Attach. When you want him to... By justaviking ( 7 Years Ago )
Forum Post I don't think using LINK can place the prop in between the arms. By vepop ( 7 Years Ago )
Forum Post When he said "attached it to to his HANDS," I didn't really notice... By justaviking ( 7 Years Ago )
Forum Post I've attached it (a letter 'X') to just one hand and the way it moves... By tallon ( 7 Years Ago )
Forum Post D'oh! So sorry... I used the "Latest" view for the forum, and forgot... By justaviking ( 7 Years Ago )
Forum Post When you add a prop to a character, in composer mode, you are adding... By jlittle ( 7 Years Ago )
Forum Post Thanks jlittle for that info - I think I understand it a little better... By tallon ( 7 Years Ago )
Forum Post As vepop suggested, you need to make the character prop invisible at... By jlittle ( 7 Years Ago )
Forum Post Yes, I understand that suggestion, but it would look crap because it's... By tallon ( 7 Years Ago )
Forum Post Here is a quick test of a character prop dropped, turned invisible and... By jlittle ( 7 Years Ago )
Forum Post Hi Jeff - many thanks for that. I see what you mean about having to... By tallon ( 7 Years Ago )
Forum Post Hi, How about having a different camera viewpoint? Once prop is... By vepop ( 7 Years Ago )
Forum Post Thanks for those suggestions - the change of camera wont work for what... By tallon ( 7 Years Ago )
Forum Post The double character, as vepop suggested, is probably your best bet.... By jlittle ( 7 Years Ago )
Forum Post That's what I tried, but it's impossible to place the new item between... By tallon ( 7 Years Ago )
