best Iray setting for a sharp image
Posted By nealtucker 7 Years Ago
nealtucker
nealtucker
Posts: 209, Visits: 1.3K
I did a few test shots in iclone with iray using 500 iterations and 1200 iterations but I find the images are a bit soft and not as sharp as an iclone render grab, should the iterations be higher?
Also when you save out the still image of the iray and the still image using the iclone export, the iray image is about 10 / 15% smaller?
I do like the iray stills in iclone but how to get the best image possible I'm not too sure at the moment,,,,,all very new.https://forum.reallusion.com/uploads/images/e784828b-3f29-4851-8a2c-42de.png
https://forum.reallusion.com/uploads/images/6a914dcb-4759-40e5-be78-79e0.bmp
View my latest Iclone project THEY ARE HERE Renegades versus the overlords Resize Editor
Well, *the best possible* would comment with individual preferences.
But if you are looking to get the sharpest possible output and don't mind jagged edges iClone render produce,
then you may set Anti-aliasing Radius to 0 in Iray Render settings and avoid using denoiser.
nealtucker
nealtucker
Thanks for the Tip 4u2ges, with so many options it good to be pointed in the right direction.
Cheers
N.
As to the Iray render size, it has its own settings. Make sure that you have selected iClone Export Size in the Preview Settings:
https://forum.reallusion.com/uploads/images/09941e65-0ef0-42eb-9317-08f7.png
justaviking
justaviking
Posts: 8.2K, Visits: 26.5K
The perception of "sharp" will also be affected by the contrast of the colors and the softness/sharpness of shadows, plus any focal (depth of field) issues, in addition to the actual "rendering" settings discussed previously.
There are some color grading options in Iray, but you could also experiment with that some in post production.
For the shadows, a small light object, will produce a sharp-edged shadow in Iray, while a larger light-emitting object will produce software shadows, just like in real life.  Consider the difference between a bright flashlight and a large window.  (That's in addition to, or separate from, IBL contributions.)
