CrazyTalk with Multiple Backgrounds?
Posted By asm_td 16 Years Ago
bpushard
bpushard
Posted 16 Years Ago
Junior Member (184 reputation)Junior Member (184 reputation)Junior Member (184 reputation)Junior Member (184 reputation)Junior Member (184 reputation)Junior Member (184 reputation)Junior Member (184 reputation)Junior Member (184 reputation)Junior Member (184 reputation)
Last Active: 13 Years Ago
Posts: 3, Visits: 32
Thanks for the timely and complete response.
Be well.
Posted 16 Years Ago
This can be done in Crazytalk 6 Pro (not Standard) by using the SFX Swap track of the Timeline. You will need to first create a background mask for your characters(s) as described HERE.
For example:
Double click on the SFX Swap track of the Timeline at the desired frame.
The Special Effects panel will open.
Select an effect such as Image Overlay - Full Screen (from dropdown) - A_Full
Then switch to Modify and select Image Import. Choose your desired background.
On the SFX Swap track drag the newly added background effect to the desired length.
Now repeat the above to add further backgrounds along the timeline at the required frames.
You can find out in detail how to use the SFX tracks in the Help Guide HERE.
bpushard
bpushard
Posted 16 Years Ago
I have the same interest. I am trying to add a story time to our website with animated readers and changing background scenes. I am using 6.13 standard. Any help/info will be appreciated.
Thanks.
asm_td
asm_td
Posted 16 Years Ago
Junior Member (229 reputation)Junior Member (229 reputation)Junior Member (229 reputation)Junior Member (229 reputation)Junior Member (229 reputation)Junior Member (229 reputation)Junior Member (229 reputation)Junior Member (229 reputation)Junior Member (229 reputation)
Last Active: 16 Years Ago
Posts: 3, Visits: 6
This is in relation to my previous post, but figured I'd break it out!
Is it possible to create one CrazyTalk project with multiple background images? So basically, the character would remain static (well, he would be animated, of course!) but the background would change depending on what he's discussing?
Thanks in advance,
Christina
