3d guy1
3d guy1
Visits: 1.6K
I have 5 and 6, but barely touched them. I remember trying to get DAZ characters in through the pipeline and gave up at how difficult it was.
Also when I looked at the render quality I was major dissapointed.
I mainly use Poser with Octane current.
Doing animations in poser is tough, especially when you add more than one character. But the quality is good.
I was rendering today, with Octane, and got it down to 10 seconds total, a frame. 3 - 4 seconds render, and octane calculates for 7 seconds. Of course it was a very light scene.
I see some people have elaborate work flows, importing DAZ characters, animating, exporting to Max or C4D to render. That seems way time consuming.
I really like to simplify and speed up.
thanks for any opinions.
PS will Iclone 8 have Brigade render?
Last Active: 9 days ago
Posts: 5.7K,
Visits: 26.5K
If your PC system is powerful enough then there is no reason why you shouldn't get iClone 7. In order to get the most out of the new version you will need a Graphic card with at least 8 GB of video RAM - 12 GB would be even better. It will run with a 4 GB card, but expect some issues if your scene gets overloaded with visual "goodies". As for iClone 8 - going on past experiences this version won't be available until late 2019, early 2020.
GOETZIWOOD STUDIOS
GOETZIWOOD STUDIOS
Posts: 1.2K,
Visits: 7.2K
wd70 (3/13/2018) ../..PS will Iclone 8 have Brigade render?Unfortunately Reallusion has chosen the iRay path for now, probably to be in par with Daz3D. Nothing prevents them to add Brigade later on though, but there has been no indication nor announcement so far about such initiative.
-- guy rabiller | GOETZIWOOD STUDIOS "N.O.E." (Nations Of Earth) Sci-Fi TV Show, Showrunner.
3d guy1
3d guy1
Visits: 1.6K
Thanks guys,
My system appears powerful enough, with NVIDIA gpu.
I'm just trying to determine if I will ever use 7, since I never used 5, or 6. { only upgraded for sale price reasons}
I'm not sure about the PBR rendering - although it's an improvement. I'm pretty well used to the Octane look.
Some have posted its not at the level of Unity PBR, for some reason. What about Blender Evee PBR?
Is exporting an iclone 7 scene to Blender Evee, or cycles, a one button process?
How about exporting an iclone 7 scene to LIGHTWAVE/ OCTANE? is that one button, or do you have to re- texture everything?
Finally, any estimate of when IRAY will be onboard?
Pixtim
Pixtim
Visits: 10.7K
I work with Cinema 4D. when I integrated Iclone 6.5 into my workflow, it was a little hard work. Today is very different. On the one hand the quality of rendering allows me to make certain project only with Iclone and others in part because we can now recover animated cameras without problem. We can do rendering with alpha for integration in post prod (it still lacks renderings by layers and masks objects ... but it is planned in the next version).
On the other hand, I was able to refine my workflow for exporting 3D animation. I had tried the Alembic export to take advantage of the physical animation of the clothes and the hair, but the weight of the files generated and the problem of the non transferred textures made me leave this track. So today, I'm exporting the animated characters in fbx directly from the built-in Iclone 7. I save the bitmap of the weight cards and I found a miracle function in a Cinema4D plug'in to convert me these bitmap in weight map for vertex (used for the physical dynamics in Cinema4D) Dynamic animations are generated from the movement of the fbx by the physics engine Cinema4D ... and it works really very well! Light and efficient! (The only thing is that this weight map conversion function is a function of the X-particle particles plug'in .. it is certain that if you only buy this plug'in for that ... it's is a bit pricey ...)
Ogier
3d guy1
3d guy1
Visits: 1.6K
............ok
...................to the PBR rendering fits your compositing workflow?
................ok not sure what you mean. is this import/ export of FBX?
...................So version 7 is the first for alpha channel renders?
On the other hand, I was able to refine my workflow for exporting 3D animation . I had tried the Alembic export to take advantage of the physical animation of the clothes and the hair, but the weight of the files generated and the problem of the non transferred textures made me leave this track.
................so Alembics not working out? file sizes too big?
............so 7.2 the FBX export of characters works for you? to C4D?
............little confused here. But your saying FBX TO C4D is working well current?
thanks
3d guy1
3d guy1
Visits: 1.6K
grabiller (3/13/2018)
wd70 (3/13/2018) ../..PS will Iclone 8 have Brigade render?Unfortunately Reallusion has chosen the iRay path for now, probably to be in par with Daz3D. Nothing prevents them to add Brigade later on though, but there has been no indication nor announcement so far about such initiative. well Iray, certainly wont be realtime. some say its around the speed of Octane, but I dont know. I dont understand why no one submitted ICLONE for an Octane plugin. everyone else has it now.
GOETZIWOOD STUDIOS
GOETZIWOOD STUDIOS
Posts: 1.2K,
Visits: 7.2K
wd70 (3/15/2018)
wd70 (3/13/2018) ../..PS will Iclone 8 have Brigade render?Unfortunately Reallusion has chosen the iRay path for now, probably to be in par with Daz3D. Nothing prevents them to add Brigade later on though, but there has been no indication nor announcement so far about such initiative. well Iray, certainly wont be realtime. some say its around the speed of Octane, but I dont know. I dont understand why no one submitted ICLONE for an Octane plugin. everyone else has it now. Because hardcore iClone film makers dont really care about Octane, iRay, Indigo and such. What they want is a realtime renderer that works and be in par with state of the art nowadays realtime renderers (ie Unreal) as the true nature of iClone, at least at first, was to create realtime aniimations and renderings (machinima). Newcomers like you often think iClone is just another DCC tool with some magic features that will allow them to create more easily things they have hard time to create in other DCC tools, so they tend to bend iClone towards other "standard" DCC tools. Which we do not want of course. Or else better use the other DCC tools. That said, it is just a matter of time, 5 to 10 years from now it is probable that Octane, iRay and such renderers will be able to produce the needed renderings below a 2 seconds time frame if not in realtime. At this point iClone will be useless in terms of "realtime renderer", that's probably why they try to develop features not easily found in other DCC tools (mocap + facial capture handling, puppeteering, character creation toolkit, etc..) and have opened their business to the gaming market.
3d guy1
3d guy1
Visits: 1.6K
Because hardcore iClone film makers dont really care about Octane, iRay, Indigo and such. What they want is a realtime renderer that works and be in par with state of the art nowadays realtime renderers (ie Unreal) ................ is there something preventing this now? as the true nature of iClone, at least at first, was to create realtime aniimations and renderings (machinima). Newcomers like you often think iClone is just another DCC tool with some magic features that will allow them to create more easily things they have hard time to create in other DCC tools, so they tend to bend iClone towards other "standard" DCC tools. .....................apparently IRAY and TRACKING are on the 2018 roadmap. Those arent exactly gaming or machina tools. Which we do not want of course. ......................who is we? See Roadmap above. Or else better use the other DCC tools. That said, it is just a matter of time, 5 to 10 years from now it is probable that Octane, iRay and such renderers will be able to produce the needed renderings below a 2 seconds time frame if not in realtime. At this point iClone will be useless in terms of "realtime renderer", that's probably why they try to develop features not easily found in other DCC tools (mocap + facial capture handling, puppeteering, character creation toolkit, etc..) and have opened their business to the gaming market. -- guy rabiller | radfac founder | 3d technical director | youtube channel
GOETZIWOOD STUDIOS
GOETZIWOOD STUDIOS
Posts: 1.2K,
Visits: 7.2K
wd70 (3/16/2018) Because hardcore iClone film makers dont really care about Octane, iRay, Indigo and such. What they want is a realtime renderer that works and be in par with state of the art nowadays realtime renderers (ie Unreal) ................ is there something preventing this now?Reallusion. wd70 (3/16/2018) as the true nature of iClone, at least at first, was to create realtime aniimations and renderings (machinima). Newcomers like you often think iClone is just another DCC tool with some magic features that will allow them to create more easily things they have hard time to create in other DCC tools, so they tend to bend iClone towards other "standard" DCC tools. .....................apparently IRAY and TRACKING are on the 2018 roadmap. Those arent exactly gaming or machina tools.
That's the point. We don't need those. But the roadmap is made by Reallusion, not by us. wd70 (3/16/2018) Which we do not want of course. ......................who is we? See Roadmap above.
iClone hardcore film/machinima makers. Again, we do not make the roadmap, Reallusion does.
