Hair files
Posted By patrick-coudert 8 Years Ago
patrick-coudert
patrick-coudert
Senior Member (320 reputation)Senior Member (320 reputation)Senior Member (320 reputation)Senior Member (320 reputation)Senior Member (320 reputation)Senior Member (320 reputation)Senior Member (320 reputation)Senior Member (320 reputation)Senior Member (320 reputation)
Last Active: 8 Years Ago
Posts: 2, Visits: 77
Hello
In Crazytalk 8 pipeline is it possible to use and how, Iclone/CC Hairs ?
And in Iclone7 or CC2, 3dxchange7 pipeline is it possible to use Crazytalk 8 pipiline hairs ?
Thanks a lot
Hi... You can import iClone .iHair files into CrazyTalk 8 Pipeline or you can simply import an .iAvatar file. You can't however transfer CrazyTalk 8 hair to iClone 7.
jlorue
jlorue
Senior Member (459 reputation)Senior Member (459 reputation)Senior Member (459 reputation)Senior Member (459 reputation)Senior Member (459 reputation)Senior Member (459 reputation)Senior Member (459 reputation)Senior Member (459 reputation)Senior Member (459 reputation)
Posts: 8, Visits: 57
Hi, I tried to drag&drop a CCHair in CrazyTalk8 (to more specific the "Faux Hawk" model), and I got the message "corrupted file"... How can I use that hair into CrazyTalk8?
jlorue (3/26/2018)
Hi... Try doing the following:
1. Add the Faux Hawk to an avatar in Character Creator.
2. Select File > Export > iAvatar
3. Change the export option for Version to iClone 6.5 and save the avatar somewhere convenient.
4. In CrazyTalk 8 select File > Import > iAvatar and import the file you just exported from CC
5. Now in CrazyTalk 8 switch to the Actor Elements > Hair tab.
6. Click the Add / Save As button at the bottom of Content Manager.
7. This will save the hair in CT8 format for later use.
I hope this helps. :)
jlorue
jlorue
It worked! Thank you very much Peter
Q3Robotics
Q3Robotics
New Member (3 reputation)New Member (3 reputation)New Member (3 reputation)New Member (3 reputation)New Member (3 reputation)New Member (3 reputation)New Member (3 reputation)New Member (3 reputation)New Member (3 reputation)
Last Active: 7 Years Ago
Posts: 1, Visits: 18
Hi there,
I am using Character Creator 3 and Crazy Talk 8.  I followed the steps above for both the iAvatar and just the iHair.  I am still receiving a Corrupted Hair file error message however when I try to import into Crazy Talk.  Specifically, I am trying to move the Bride Bun which I purchased.  Is Character Creator 3 the correct software to use to do this?
Hi...
CrazyTalk 8 is only compatible with .iAvatars created in iClone 6 or Character Creator 1 or 2. As Character Creator 3 doesn't allow export in these formats, any avatars saved in CC3 won't be compatible with CrazyTalk 8.
To be able to export avatars with hair for use CrazyTalk 8, you will need Character Creator 2 or iClone 6. If you don't have a download available for either product in your Reallusion Account > Registration page (or in the Reallusion Hub), you can contact Customer Support using the link below. If you explain you need it for CrazyTalk 8 they should be able to provide a copy of CC2 and a serial number for you. You can have both CC2 and CC3 installed at the same time so it won't affect your use of the current version.
ido.s
ido.s
Posts: 3, Visits: 14
how can I import the hair files from CC3 or iclone into crazytalk 8 ?
ido.s (3/16/2020)
Content from iClone 7 or Character Creator 3 is not compatible with CrazyTalk 8 unfortunately. Only content from iClone 6 or Character Creator 2 is compatible.
If you like the head creation features of CrazyTalk 8 then you may like to consider Headshot for Character Creator 3. This offers vastly improved head creation using just a single photo.
