slavoisard
slavoisard
Visits: 699
Just got a very good email offer on Total Plants 2 collection but I'm hesitating to buy this as the trees and plants are still not working. Anybody got any feedback about this being fixed ?
Best regards,
Postfrosch
Postfrosch
Posts: 6.9K,
Visits: 18.4K
I do not know if I should advise you or can accept the offer for the "Total Palnts" and buy the package. I do not know if I would make a mistake. I have often read that the Speedtrees would not run under IC 7.2 or would not be displayed. Also a user in the German forum had after the UZpdate on 7.2 a Speedtree problem. The trees were not visible in the loaded project (created with 7.1). After reloading de Speetrees were then visible in the project. So I did a little test. 1. IC 6 project loaded: Speedtree visible and functional 2. IC 7.1 project loaded - Speedtrees visible and functional 3. IC 7.2 project newly created - Project closed - reloaded: Speedtrees are radio ready and visible. (this is the clip - just a test)
I do not seem to have any problems with the Speedtrees from IC 6 Greets from Germany Postfrosch
Posts: 9.2K,
Visits: 22.1K
Total Plants 2 in 7.2 works fine for me. Originally there was an issue (IIRC something about Mixmoves and directory structure) but I haven't been able to duplicate that problem since. I would buy with confidence -- RL will make good if it doesn't work for you.
Posts: 9.2K,
Visits: 22.1K
Of course now that I wrote that I find I can't get the wind settings to work at all. Hmmm, anyone else having this problem? Edit: Nevermind. I was working with a very complicated scene earlier and had "Quick Mode" on -- which won't display physics movement. Sigh -- learn something every single day about iClone. All is well.
slavoisard
slavoisard
Visits: 699
So I did buy this wonderful Total Plant 2 package... and installed it. But I'm still having nothing appearing; Sounds like it's a problem with PopCorn FX. Anybody has news from Reallusion about a patch for this ?
justaviking
justaviking
Posts: 8.2K,
Visits: 26.5K
I don't have a technical solution, but as KT said, Reallusion will make things right. Keep an eye on the return policy dates. Reallusion will honor refunds, so no worries in that regard. Hopefully you get it to work.
Posts: 9.2K,
Visits: 22.1K
slavoisard (1/29/2018) So I did buy this wonderful Total Plant 2 package... and installed it. But I'm still having nothing appearing; Sounds like it's a problem with PopCorn FX. Anybody has news from Reallusion about a patch for this ? It's not a PopcornFX problem -- I use Speedtrees with Popcorn just fine (made my Disney fireworks animation with it). Some folks found having a Mixmoves pack (um, Communications?) installed was the problem, but I have that pack as well and it works (then again, I've moved around my directories quite a bit so they aren't at the defaults). But you ought to be able to get Speedtrees working -- you DO have an NVidia card, right?
TonyDPrime
TonyDPrime
Posts: 3.4K,
Visits: 12.4K
One upon a time, in a desolate land, filled with no trees at all... I reinstalled iClone to find it fixed my invisible Speed Tree issue. Now, upon reinstalling, I had named the content folder from "Template" to "TemplateA" to keep it from being touched by the new reinstall, so I had a newly created content folder "Template", and an older folder "TemplateA", which was full of content.
After testing the new install and finding that SpeedTrees worked, I switched my content folder names back around so that I had my old folder with the content named "Template". However, I found that if I then used this older folder now, the SpeedTree issue was back. So, I switched the Template names around back, and, when I used the newer created Template folder that was smaller, the trees worked fine. I flipped my content folders back and forth, and found the pattern, and deduced it must be something about, or inside, the old folder.
What I discovered through tests was that the folder for MixMoves was the key. Specifically, "00_Female (CC)"
...\Template\iClone 7 Template\iClone Template\MographMotion\00_Female (CC)
If you rename it to, say "00_Female (CC) A", or anything different than it was, it disables Mix Moves from working. BUT...it returns the trees!
As such, even if you have the issue, you can change it back and forth depending on your project needs.
So, rename the folder "00_Female (CC)" to something different, like "00_Female (CC) A", or "RL-Please_Fix_the_Bug_with_MixMoves_and_SpeedTrees...NOW".... ... and, GO GREEN
thebiz.movies
thebiz.movies
Last Active: 3 Months Ago
Posts: 2.1K,
Visits: 42.3K
I cannot confirm this on my machine. I've updated the latest video drivers but they still dont show up for me. Went and renamed the folder as you suggested. Rebooted the application. Trees still not showing up. Very frustrating (but very thankful for your efforts).
Posts: 9.2K,
Visits: 22.1K
You might try reinstalling iClone (make sure you completely remove it first, though). If that still doesn't work (iClone will keep your folder structures intact and all content there during a reinstall) then copy all your content off somewhere, reinstall iClone, and install first Speedtrees and see if it works (which I'm sure it will). Then slowly reinstall all the rest. The alternative (and it's fine) is to file a troubleticket but I'm sure they will have a reinstall as a first troubleshooting step (and perhaps all the rest that I suggest).
