Slayerazazel
Slayerazazel
Visits: 7.3K
LINK TO FREEBIE MODULE IN MY STORE https://marketplace.reallusion.com/store/ReaperProductions/module/42022Hi guys, I have just recently started playing around with ZBrush and thought i'd post my "Beginner" work here for you guys for free while learning the full capabilities of the software. Any products uploaded for free in this section, will not be maintained nor fixed or updated etc.. But i will only upload freebies that are generally functional and look ok enough that i would actually use them. I will add new items when available to this post instead of creating new posts for each item. First item. A face mask with some basic textures. I didn't spend much time on sculpting or smoothing the mesh or texturing due to me just working out my workflow, but i think it turned out fine. And would be best suited for hooded characters. Available for export if you wish to re edit the mesh or textures etc. Uploaded as a CC Accessory attached to the model as you see below, and can be used in iClone 7 also. Adjustment may be required with different face structures. I hope you enjoy and join me on my journey with 3D Modelling. The Mask can be found HERE
Slayerazazel
Slayerazazel
Visits: 7.3K
Snarp Farkle
Snarp Farkle
Visits: 3.6K
Thanks Slayerazazel, they look cool!
Rogue Anime
Rogue Anime
Visits: 3.4K
Wow! Thanks big guy! May I take your coat as well, sir? lol (NICE COAT!) GR8 work, though that last pic looks like Joe McPeek on a you-tube rant! ~V~
Val RogueAnanda
Slayerazazel
Slayerazazel
Visits: 7.3K
Thanks Guys @Rogue Anime, The coat is not mine, it is Reallusions from the Sorcerer pack, just darkened. https://www.reallusion.com/ContentStore/Character-Creator/pack/3D-Clothing-Sorcerer/default.htmlOr just grab the base from the content store https://city.reallusion.com/ContentPreview.aspx?i=JCC5411f0d3ca1f5e6a6The hood, assassin's pack, the pants and boots are default cc content
Slayerazazel
Slayerazazel
Visits: 7.3K
Lightsaber Basic - Free until Feb 31stA simple but sleek design.    iClone Accessory CC Accessory
NOTES: Will attach to the right hand. This is a basic lightsaber design. Use the Blade Glow Map to change color. Also changing the strength and the opacity will give you different blade strengths. There is no on/off function. This will need to be done manually by setting the opacity to 0 to 100
Color ID for the Hilt can be found in the link below if you wish to use iclones substance tools to edit Free icontent and export until Feb 31st 2018 (Price will be set to 200 iContent / 300 Export after the above date)
Slayerazazel
Slayerazazel
Visits: 7.3K
pedrosura
pedrosura
Visits: 5.7K
Thank you. Really cool
Rogue Anime
Rogue Anime
Visits: 3.4K
Slayerazazel (1/31/2018) @Rogue Anime, The coat is not mine, it is Reallusions from the Sorcerer pack@slayerazazal - The "May I take your coat, sir" was actually a 'butler' joke! ;) I have the pack - But thanks for the info for everyone ~V~
Val RogueAnanda
Angelom4
Angelom4
Visits: 3
Not bad at all and the achievement is at the top. Thanks for sharing.
