Akantha_Nox
Akantha_Nox
Visits: 200
How can you activate the lights?
Jfrog
Visits: 4.7K
I found it! Thanks.
Ryzen R9 5950x, RTX 3090, 128Gb Ram ,2 x 2 TB Samsung 980 Pro M.2 SSD
Horror Stories in VR Immersive Sound VR Immersive Sound VR on Oculus TV
Jfrog
Visits: 4.7K
I already posted this question on another part of the forum but maybe this is the place to have a quicker answer: "One MechREX texture style is composed of three different sets of PBR materials used separately for head, body, tail, and leg segments. Additional materials have been provided in 4K resolution for ultimate render quality and details." Does anybody knows where to find the 4k textures for the Battle Mech series models? I really need the 4k version as soon as possible.
Thanks for your help!
Posts: 9.2K,
Visits: 22.1K
Glad to hear you could get the content. Yeah, it's a bit odd they don't give you opacity maps but they are easy to create. I created one in less than 30 seconds for the female:
rogyru
rogyru
Visits: 1.3K
Thanks
I downloaded them again and now they have all shown up in the others section in CC that just fine. Only problem i have now is the helmet dont have a opacity map for the visor. Why would you not make a opacity map for a helmet visor ???
Posts: 9.2K,
Visits: 22.1K
Well, it isn't all that much -- it's just two folders, Adroid Armor_Female and Brute Armor_Male, and they go in Cloth/Others. All the parts are in there (assuming you bought both the suits) under a main folder called Battle Mech Series. But you should definitely have that -- if that isn't installing after redownloading put in a help ticket.
rogyru
rogyru
Visits: 1.3K
Thanks but its still the same checked the install logs and there is nothing for CC. The items have not been put in to individual folders in side of Character creator .
Posts: 9.2K,
Visits: 22.1K
rogyrue (9/29/2017) I picked this up today. Looks very good so far. But i cant find any reference to any of the items in any of my CC folders when i am using character creator ? apart from the helmuts in accessories. Am i missing some thing ?
I actually had to manually move some things over. Let me check for a moment... Ah, it was the helmets themselves. They installed for me not in Accessories (like you have) but in the "Heads" section (there is Accessories/Heads and there is Heads, and one is NOT the other). I moved them over and all was well. Sounds like you have the opposite problem, that the other stuff didn't install for you (this pack might just have a flaky installer, since Rampa had no problems). I think the first thing I'd do would be to redownload the RLD and try again. Then if you still can't find the stuff do a search (the RLD will tell you where you can find everything) and move stuff over manually if you have to (I move stuff around manually in CC all the time anyway: kind of hate where stuff is stored by default).
rogyru
rogyru
Visits: 1.3K
Miranda (RL)
Miranda (RL)
Posts: 1.8K,
Visits: 11.2K
Hi Chris, Thanks for informing us this issue!! The issue was fixed yesterday, and our Support Team have sent out a notification to inform users who purchased this pack to download the pack again. videodv (9/23/2017) In Motions the MechRex folder installs as Rex you need to rename it to work correctly RL need to look at this and change it.
Regards Chris.
