studio_savyra
studio_savyra
Visits: 74
Hi HiveMind. Can anyone assist me with this problem please - I have a figure that had a very nasty shadow under the chin, which I tried to eliminate in Photoshop by fixing the face map. This helped a bit but the shadow still hung there like a black goatee. This is with the no background that one starts in. I then used the 'gallery' atmosphere and lighting and the white/grey blend background under backgrounds. This works really well now, but I'd prefer a completely blank background but with the gallery lighting. Is that possible, and how would I do that? There's no option for a blank or 'none' background. Only other option is to put in my own greenscreen. Will do this if I have to but would like to know other options so I can float the figure over stuff I want to show in the final video. ==========================================================8 hours later Right - have solved it by using the plain old no background, and the shading on my new figure is better. But I'd still like to know what to do in thefuture with this problem please if anyone has some ideas.
niceblinkluck
niceblinkluck
Visits: 1.3K
HMM..THANKS...SO ITS STILL PRETTY USELESS WHERE CARTOON CHARACTERS ARE CONCERNED....ANY CHARACTER WHO DOESNT HAVE A BALD HEAD OR VERY CLOSE CUT HAIRCUT IS IMPOSSIBLE TO VISUALISE. IT MAY TAKE REALLUSION A FEW YEARS TO WORK AROUND THIS... BUT FOR THE MOMENT...DRAWN CHARCATERS WHO ARE NOT BALD ARE IMPOSSIBLE TO TO USE IN THIS SOFTWARE....IF YOU WANT TO DROP THE HEAD INTO AN ICLONE CHARACTER...I KNOW REALLUSION WILL BE WORKING ON THIS... SO I'LL CHECK BAK IN A COUPLE OF YEARS...
AverageJoe
AverageJoe
Posts: 2.4K,
Visits: 10.1K
niceblinkluck (2/6/2016) ah...thought this maybe the case...I wanted to have a drawn cartoon character front and side view head with long hair then send it over to Iclone. to make a full character... I now see my only option is to have a bald woman ...and animate the drawn hair over it in other software....its a bit drawn out.In the promo videos and information, they have a "drawn" character that they turned into a fully "drawn" 3d character via the iClone pipeline, but have never given any information on how to do it. iClone does have toon shading, but I'm willing to bet the fully drawn character pipeline will only be viable for realistically drawn characters, and not necessarily a "toon" character. That is if they ever reveal the mystery of the "drawn" character, as well as the man in the painting character. It's not uncommon at all for RL's marketing and promo material to be completely misleading.
niceblinkluck
niceblinkluck
Visits: 1.3K
AverageJoe
AverageJoe
Posts: 2.4K,
Visits: 10.1K
niceblinkluck (2/5/2016) im very interested in making a drawn cartoon using crazytalk 8 ...now the face creation I can see is easy....but if I have a female cartoon character with long hair how do I go about it? its no good sticking on hair for regular characters from a library because the difference in styles would be vast. it would be good if I could create my own cartoon hair styles and use themIf it's truly to be a "drawn cartoon", you might be better off with the 2D face creation as opposed to the 3D creation. 3D will leave you with a bald character, and little to no decent choices for hair, whereas the 2D creation will use whatever hair is already "drawn" onto your figure.
I'd like to see tutorials on how the cartoon man as well as the man in the painting included with CT8 were created...
niceblinkluck
niceblinkluck
Visits: 1.3K
redrubyslippers
redrubyslippers
Posted 11 Years Ago
Visits: 1.1K
Thanks...I'll have a good look at this,see if it helps
RRS
Eric (RL)
Eric (RL)
Posted 11 Years Ago
Last Active: 10 Years Ago
Visits: 1.0K
Hi redrubyslippers! It also could be that when you transfer the character's head to CC, the character already contains morph data. I would suggest that you try resetting the character to the default morph, as described in this post: https://forum.reallusion.com/264554/How-to-get-a-exact-likeness-when-bringing-CT-8-head-into-CC
______________________________________
Eric (RL) Forum Moderator
Reallusion, Inc. https://forum.reallusion.com
"Simplicity is the ultimate sophistication." - Leonardo da Vinci
redrubyslippers
redrubyslippers
Posted 11 Years Ago
Visits: 1.1K
hi thanks for the video,hmmm it still gives not very good results when migrated to iclone.. i did a pretty good head of sly stallone in CT but the migration was awful.. looked nothing like the figure in CT.. could have sworn it had downs syndrome.. i noticed your reply..................
quote ""However, since CrazyTalk 8 and iClone uses different rendering engine, the result may look slightly different even though the mesh is exactly the same. To match what you see on CrazyTalk 8, try giving it a brighter scene lighting, and changes the focal distance of the camera lens to something far: like 200mm. You should be able to get a pretty close result.""
200 mm far... no thats not what im after..well ive almost run out of exports now with the demo, ..ill have to see much more results with better likeness before i commit to buying,, yet again im disappointed, that it doesnt do it for me, dont get me wrong its a good product , but it just doesnt do what it says on the tin for me at this time
RRS
Eric (RL)
Eric (RL)
Posted 11 Years Ago
Visits: 1.0K
Hi redrubyslippers, Added a new video that talks about importing RLHead to iClone 6 and Character Creator. You can check out the video with this direct link. https://www.youtube.com/watch?v=aDhB1IQHUFU&t=9m23s#However, since CrazyTalk 8 and iClone uses different rendering engine, the result may look slightly different even though the mesh is exactly the same. To match what you see on CrazyTalk 8, try giving it a brighter scene lighting, and changes the focal distance of the camera lens to something far: like 200mm. You should be able to get a pretty close result.
